Hot - Free "Check-Engine Light" Diagnostic at Auto Zone
im2smrt4u
1,912
Hot deal for me! The light is on in my '97 Windstar and it beeps all the time! Maybe now I can figure out what is wrong!
ElFenix
102,389
8,547
best thing ever since that light will come on if the tank isn't presurized right. $80 at a dealer or a shop to find out the cap isn't screwed on. heh
Thanks for the HOT DEAL !
I am a 20 yr plus A.S.E certified Automotive Technician and have been looking for a OBD II compliant scanner of late.
I was about to spend big $ on a new scanner,now I am just going to order the $80 PC link and be on my merry way :):):D
Thank You ! :D:D:D
wasamicron
360
I have a '00 Dodge Dakota. Check engine light came on. Used Google to find out how to check code. U can turn key "on-off", "on-off", then "on" for about 20 seconds. Code will display in digital odommeter. In my case, code P0455. Looked up code on internet at obdii.com. Then, I looked up a way to clear the code. U can remove the negative cable from battery, then turn key to "on" for several seconds. Clears the codes. All of this for a lose gas cap.:eek:
