Originally posted by: DrPizza
<something about firestone tires>
who are you replying to?
Originally posted by: Ness
Originally posted by: lMlHuxley
Ok, apparently the jurors felt the coffee was so hot that it had nearly malicious intent. They were also mad becuase mcdonalds did not feel sympathy for the old woman who burned herself. Once they were shown the graphic images, juries always fold. All coffee can cause sever burns and that is common knowledge. Humans understand that coffee=hot. I think mcdonalds should have paid her medical costs and the jury should have agreed to that plus the time she has had to take off of work and minor pain and suffering compensation. Anything above that is out of hand.
Once again, McDonald's had prior knowledge that their coffee was causing severe burns and it was found that their competetor's coffee was 20 degrees lower, at a temperature that still made good coffee but wouldn't have given someone third degree burns.
you're saying that the reason the jurors themselves said was the reason they didn't laugh the old woman out of court was not the reason they pinned mcdonalds for the money?
Uhhh, how many SUV rollovers have their been as a result of front tire (Firestone) blowouts?
A hundred even?
Geez, why is it that there are billions upon billions of trips in SUV's each year, but only a couple hundred people are injured (or killed) during a trip because of a front tire blowout leading to a rollover??
Ya' know... if they only blow out and cause the vehicle to roll over, injuring or killing the occupants 1 out of every 40 million trips, then they must be a heck of a lot safer than McD's coffee...
Firestone didn't make the people drive 65 mph... the people should have known that if they were driving faster than 5 or 10 mph and there was a blowout, there was a risk of rolling over. It's their own fault. Firestone can't control how their product is used.
If you think McD's coffee is safe because so many cups are consumed safely, then I want to know what's wrong with the preceding argument.
No. I got the feeling that Huxley was being sarcastic about the coffee having malicious intent. Saying it was malicious is a falsehood and I didn't want anyone to think they there was some guy at McD's HQ snickering to himself about intentionally making coffee hot enough to burn people... with that as the sole purpose .
While I think their reasoning for the hot coffee was legitimate (as in, they had a reason for it other than just wanting to make it hot and by no means were TRYING to burn people) I still think the ignored claims of burns were sufficient enough to show that McDonald's was either careless or ignorant in their choice to serve coffee that hot.
A hundred even?
:roll:
because firestone tires are designed NOT to blow out. because firestone tires are NOT SUPPOSED to go flat.
Coffee is SUPPOSED to be hot, unless you specifically ask for ice coffee of course.
they were SETTLED, hence they weren't ignored.
do you think mcd's is the first company to have settled matters out of court because changing the temp of the coffee may have affected their business too much?
They also gave the success of their coffee to the higher temperature and so they made it that way.
Apparently they were ignored, because McD's still did nothing about the harmful temperature of their coffee.
Why use these alternate methods when they have one that people already like and buy? They would spend more redeveloping the process than they have in law suitsOriginally posted by: Ness
I've already stated reasons why the success of their coffee cannot be contributed entirely to it's heat, as well as alternative means involving still allowing the flavor to be released into the coffee by brewing at higher temperatures, but serving it at lower temperatures.
A hundred even?
:roll:
I'm not a genius with coffee, but everything I have read says the flavor is released at those temperatures, not that it won't stay at lower temperatures.
A hundred even?
:roll:
The primary design of a tire is to make a car go forward smoothly and provide an adequate amount of traction on a variety of road surfaces. Of course it's important to also consider whether they would blow out or not.
Coffee is NOT designed to cause 3rd degree burns in 2 or 3 seconds. Coffee is not designed to require skin grafts. Does it really take that much effort to think twice about your design if those sorts of things are happening? Firestone tires WERE blowing out - not a good thing. Firestone realized it was a problem and addressed the problem. Coffee WAS burning people. McDonald's chose to be callous about it. A simple solution would be to brew it at a higher temperature and serve it at a slightly lower but safer temperature.
A hundred even?
:roll:
:roll:
IF used as designed, most tires don't blow out. firestones were even under normal usage. hence they are liable.
IF the coffee was consumed in the normal fashion (1 billion cups a year served and the majority were not burned) then the person would not sustain 3rd degree burns.
now, let's carry your parrellel a bit farther. so the person driving a car with firestones saw an area with lots of nails, boards with nails in them etc and decided to run over these boards. if the tire blew out under those circumstances who's liable?
in the case of firestone, the tires were blowing out even under NORMAL USAGE, hence the manufacturer was liable (btw, weren't they sued? and wasn't it the lawsuit that made them make the changes? you make it sound like they did it out of the goodness of their hearts vs a mcd's which was callous. :roll🙂.
in the case of McDonalds coffee, 1 BILLION cups a year was being consumed with a VERY VERY small fraction getting 3rd degree burns. if 999,999,300 cups of coffee were consumed without 3rd degree burns than we can safely assume that those were cases of NORMAL usage and the 700 cases of ABNORMAL usage.
A hundred even?
:roll:
:roll:
blah blah blah... we've covered this already on a few instances. The reason McDonald's was only found at partial fault was because the coffee was spilled. We know that, thanks for running it by us again and proving nothing new.
But even still a person should be able to expect that something as simple as their coffee won't hurt them.
A hundred even?
:roll:
:roll:
if you've covered it once before, just stfu. i was resonding to someone else, who's analogy was completely off base. comparing the mcdonalds thing where the woman was at fault is COMPLETELY different with the firestone incident, where the driver doing NOTHING on their part could suffer a blow out.
You would be greatly suprised how much money it costs to redevelop even the most simple task in a large operation. Yes, hot coffee can be dangerous to customers but the customers like it that hot. 160 degree coffee is still going to burn you like hades.Originally posted by: Ness
... uh.. because it is known to be dangerous to their customers...
I seriously doubt they would lose more than 2.7 million dollars redeveloping this.
But as testified in this court case, it won't cause third degree burns... and likely to not even cause second degree burns.
