Okay, why are more people not baffled by statements of 'my insulated basement is too hot, and when I purposefully humidify it, it gets too humid'? Uh...don't...use...a humidifier?
Why did you insulate the basement? That's a big mistake.
If you didn't do that, your basement would've maintained a perfect temperature all year round (ok fine, you would need some heat).
In MOST of the cases, insulating basement walls = no no
I think he forgot to put a "de" in front of that. He isn't humidifying it.
Just like I missed the "heat pump" part of his water heater. He's already doing what I suggested.
I installed an Energy Recovery Ventilation System that blows fresh air into my basement, along with a ductless heat pump in the basement (one of the four zones). I run that as well as a dehumidifier. Dehumidifier would still be needed even if you have an AC because the AC will end up making it 50 degrees in there before it removed the same amount of moisture as the dehumidifier.
Do you have electric water heating, and is it in the basement? If so you could look into those hybrid water heaters that effectively are heat pumps.
The suck up the heat in the surrounding area, condition it, and then use that to help heat up the water in addition to electric elements in the tank. They'll lower the ambient temp, condition the air, and reduce your electric bill for your water heating needs.
I'm not sure if a ducted humidifier would increase the humidity that much better than a plain ol' humidifier would.
Update: So I figured out what was causing my basement to get so hot. During the remodeling process, the contractor walled in the flexible ducting from our dryer. That ducting extends from our dryer down through the first floor and into our basement, where it is hung from basement ceiling behind a wall until it exits the house. After noticing that my basement smelled like dryer sheets one day, I opened an access panel to discover that the dryer vent had ripped. As a result, all the hot exhaust from the dryer was being discharged behind one of my newly finished walls. I replaced the ducting and voila! Cool basement. 70 degrees all the time down there now. Still have a humidity issue, but I fixed that with the whole house dehumidifier mentioned in my previous post.
BTW - my new hot water heater (Stiebel Eltron) is AWESOME! No oil usage and my electric bill only went up by$18 bucks.
How much did it cost to install the Stiebel Eltron? For my house, I would need three 60amp breakers. The cost of the instant heaters like that have come down in price.
