- Dec 10, 2005
- 28,095
- 12,723
- 136
I just saw this over on Woot.com:
7900GS OEM - $139 + $5 shipping
A 7600GT through Newegg is at least $150 and the cheapest 7900GT is about $250.
Specs from Woot:
* Manufacturer: MSI
* Series: GeForce 7
* GPU: G71
* Interface: PCI-E x16
* Core Clock: 470 MHz
* Memory Clock: 660 MHz (1320 via DDR)
* Memory Bandwidth: 42.24 GB/sec
* Shader Operations: 9400 Operations/sec
* Pixel Fill Rate: 7520 MPixels/sec
* Texture Fill Rate: 9400 MTexels/sec
* Vertex Operations: 822.5 MVertices/sec
* Framebuffer: 256 MB
* Memory Type: GDDR3
* Memory Bus Type: 64×4 (256 bit)
* DirectX Compliance: 9.0
* OpenGL Compliance: 2.0
* PS Version: 3.0
* VS Version: 3.0
* Process: 90 nm
* Fragment Pipelines: 20 (24)
* Vertex Pipelines: 7 (8)
* Texture Units: 20 (24)
* Raster Operators: 16
* Supported Operating Systems: Windows XP Home, Media Center Edition 2005 or later, Windows XP 64 (64-bit Windows extensions)
Notes:
* Includes graphics card ONLY, download drivers here or here
* To enable advanced features of the card you will need to connect power from the case power supply via a 6-Pin PCI-Express connection ? some system power supplies have them and some require an inexpensive 4-pin to 6-pin adapter
* This card has dual DVI connectors and TV-OUT jack but does not ship with DVI to VGA converters or video cables.
Specs from Woot:
* Manufacturer: MSI
* Series: GeForce 7
* GPU: G71
* PS Version: 3.0
* VS Version: 3.0
* Process: 90 nm
Notes:
