My research I did yesterday on this monitor, CPD-G500, I believe, indicates that it has a settings restoration feature whereby it will restore settings. This won't do it? Or is that the CPD-520? Here's what's said at Sony site: "Accurate Image Restoration Resets display to original factory brightness and contrast settings." This is for the G500, NOT the G520, BTW.I need to dig out the color strip and color tuning software that came with my Compaq or if someone on here can recommend some software to do a diagnostic and color tune that would be GREAT!
I assume they don't test them and if they do, they probably just plug them in and look at them for a minute or two for obvious problems. Chances are they don't adjust them. Assuming they were on lease for a year it may not be a big deal. Are these basically one year lease monitors? Actually, I don't see anything about one year lease, just one year warranty. These may have been on lease for years, AFAIK.Originally posted by: LotusNotesGuy
Buckmaster:
I checked the site every day after I placed my order, I noticed some of the monitors at Merkor, go in and out of stock FFAASSTT. When I spoke to them on the phone about my order, the rep mentioned they come and out in huge numbers and the staff gets cleans them up and turns them over as fast as possible.
I bet they ran out of stock or had some coming in and your order got caught in that gray area between 1 and 0 in stock.
Originally posted by: Dedpuhl
Ordered my Nokia 445Xpro (grade b) on Saturday night (11/10)
Shipped Monday (11/11)
Arrived Wednesday (11/13)
Now that is the fastest ground shipping i've ever seen (shipped to Baton Rouge). For $161 shipped, this monitor is PERFECT. There is a small scratch on the screen, but it is not visible when on.
This was a very good deal 🙂
Originally posted by: Jeraden
After a bit of further use, not only does this P.O.S. have 5 vertical scratches at the center of the screen, it has severe ghosting, a burned in image of what appears to be the close-program dialog (ctrl-alt-delete box), and the left side is noticeably darker than the rest of the screen. On the positive side, the text is nice and crisp! 🙂 Guess I have a new tv monitor now.
I think those shadows you notice may be artifacts you can get rid of. It may not be due to a problem with the monitor but a problem with the way it's hooked up. I once had a monitor hooked up with an extension and that introduced ghosting such as you describe. How do you have it hooked up? Can you try a different cable?Originally posted by: BuckMaster
Well I have my 19" Gateway EV910 arrived tday. Well packaged and not a single scratch on the monitor. Looks like new! Bad news is it does have a small black dot in the middle of the screen which I can live with. The problem I hate is the everything shows a shadow on the icons, letters everything. Its kinda annoying and dont like it. It not good on the eyes for a long period of time! I tried to find some drivers but cant find any for Windows XP to try and see if it helps. Also on my papper work it shows my order Grade as 'D"? Humm
Anyways Im thinking of calling them and asking about it. I can live with it but I took a gamble I guess and didnt get the results I really wanted but could of been worse.
Try posting in the Video Anandtech Forum for some expert analysis. I still think this might be fixable and may not be a problem with the monitor per se. You can also try the newsgroups (video related), and if it was me I'd do searches at Google Groups, perhaps advanced searches (specifying a certain newsgroup), if non-advanced searches don't work out. Good luck!Originally posted by: BuckMaster
Muse,
This monitor came with a seperate video cable. Not the kind thats built into the monitor itself but the kind you have to screw into both the monitor and PC. I was also curious if the cable could be bad but dont know if I have an extra one. The odd thing is it seems when I play anything using the 3D part of the card its unnoticeble. I think because most games are so dark in the back ground. You can really tell the shadow, blurryness when your using explorer, typeing a letter in word, or using anything from windows desktop.
alkemyst, Im glad you got Good Customer Service! Thats hard to find now days!! Im going to wait for some more responses from here and maybe call them and see if they have any suggestions. Maybe send them a print screen shot if it helps. If I could just get this fixed Id be SO happy! 🙂
When will this kick in? Thanks.Originally posted by: BentValve
Every monitor on this page will be 20% off with free shipping again...so think twice before buying a used one.
