Horrible problems with 4870x2 card
SilentRunning
1,493
Originally posted by: Chaotic42
Originally posted by: cmdrdredd
Originally posted by: Wreckage
This thread got locked because we are not allowed to talk about ATI in a bad way, but the 8.11 drivers have a major problem with the x2
http://forums.anandtech.com/me...=2253189&enterthread=y
That's not why it was locked at all.
Besides, we need more details about some things. Does CCC show both GPUs and show them running on a PCI-E x16 slot? Have you tried 8.10 drivers to check? Did you try setting Catalyst AI to advanced?
Yes, it shows both GPUs running on PCI-e at x16.
Graphic Bus Capability: PCIe 2.0
Maximum Bus Setting: PCIe 2.0x16
Catalyst AI is set to Advanced
I have not tried the 8.10 drivers.
As for the rest of my system:
Intel DP965LT Motherboard
Core 2 Duo E6600 @ 2.4GHz
4GB DDR2
Adaptec 29160 SCSI HBA
Fujitsu 36GB U160 SCSI - Main OS
Western Digital 750GB SATA - Storage/Programs
2xDell 24" LCD
Logitech headset
Isn't that a PCI-E 1.0a motherboard?
SolMiester
5,330
17
Originally posted by: Creig
Originally posted by: nitromullet
Why don't they just fix stuff when it's broken regardless of what month it is?
They do. And soon as they fix it, they can get it out to consumers within one month. Nvidia, on the other hand, sits on their fixes internally and only releases them once they deem they have a large enough stockpile of them. Which is usually once every 4 to 6 months.
Personally, I'll take the monthly updates.
So I guess that is a lot of bollocks then?....spreading FUD much?
n7
21,281
4
Hmm, try P35 or newer & your problems all get magically fixed i bet...
Chaotic42
35,161
2,315
Actually the 8.12 drivers magically fixed my problems. It's a staggering improvement. The card suddenly seems worth having.
Chaotic42
35,161
2,315
Originally posted by: Comdrpopnfresh
audio cleared up too? what were your audio symptoms anyhow?
Yep.
I was getting cracking weirdness and sometimes Ventrilo would start using an entire core by itself.
Dadofamunky
2,184
Wow dude. Great to see that fixed it! I was going to suggest a grounding problem between your motherboard and your mobo trey (I was having that problem with the same exact symptoms you described but fixed it) but what a relief to have a software update fix those horrible problems! You'll need to really test thoroughly, though. I'm sure you already are.
You're sure getting a lot of mileage out of that 965-based board.
Chaotic42
35,161
2,315
Yeah, it's pretty nice. I was getting 1fps in some areas with 8.11, now I'm getting 60.
Tempered81
6,374
Ah! Great news.
