imported_Reck
- Jun 24, 2004
- 1,695
- 1
- 0
Originally posted by: MikeyIs4Dcats
seriously though, how did he let it get that big??
take a metal trash can, fill with a couple of inches of gas.
stick can up to soffit, shove to jar nest loose, quickly slam on lid.
wait 15 minutes.
crack open lid, toss in a match.
works like a champ.
Funny you should mention that. We used to spray spiders with spray glue (aerosol can) and once it dries, they are mummified. Good idea though!Originally posted by: alien42
how about a creative and fun solution like a can of that hardening insulation. it would seal the hornets in.
wait 15 minutes.
works like a champ.
Heat Source....Check!
Fuel....Check!
Oxygen......?
Originally posted by: iamwiz82
I use RAID hornet killer all the time. It takes about 30 seconds to completely kill a hornet and about 10 seconds to disable it. Spray the can, run, spray another can, run, etc.
