Horn, monitor, bookshelf... what's the difference?
DesiPower
15,299
740
Have been researching speakers for HT for a while now and have seen people referring to three different kind of speakers, what's the difference? are both horn and monitor types of bookshelf? or are they three different types?
NutBucket
27,151
635
a horn is a type of tweeter. a monitor is powered speaker (amplifier built it). a bookshelf simply describes a speaker that is sized to fit on a bookshelf.
Anubis
78,712
427
tbqhwy.com
monitors are not always self powered, generlly used for sound recording/production where a neutral flat and accurate responce is needed
LoveMachine
491
Also, Horn just refers to the mounting of a driver (tweeter, mid, even sub) into a horn-shaped (gasp!) outlet. More output with less power.
alcoholbob
6,387
465
All a monitor is, is a speaker that's between the size of a satellite and a floorstander. A bookshelf speaker is also known as a standmount monitor. Although most of the times, when people say monitors, they are referring to powered monitors which the term for amplified speakers that mixing engineers use, also known as studio monitors.
A tweeter is a high frequency driver.
A horn is a type of baffle waveguide used typically for tweeters, but can also be used for midrange drivers (see Klipsch Palladium).
Horn and monitor...what exactly where you researching OP, the Chase PRO-10s?
ethebubbeth
1,740
None of those are mutually exclusive designations. You could have horn loaded active bookshelf monitors :)
DesiPower
15,299
740
Not researching anything in particular... Just researching speakers, old and new and getting confused with all these names and terminology... Thanks guys, I got what I was looking for
vshah
19,003
24
horn isn't a type of tweeter, just means that the tweeter, whatever type it is (ribbon/dome/whatever) is mounted in a horn, amplifying the sound. makes for more efficient speakers but some feel them to be heavy on the treble.
Gunbuster
23
"Bookshelf" is often a very loose definition so be sure to check the dimensions of the speaker. For instance my JBL S38's are 11-1/2" x 17-1/2" x 12-7/8" and weigh 28lbs each.
s44
9,427
16
Heh, yes. It basically just means it doesn't go all the way down to the floor.
alcoholbob
6,387
465
Yep. Genelec 1039As are also considered monitor speakers. Except they weigh 253lbs each O_O
Oyeve
22,066
883
True, my 1974 20" 130lbs color TV was listed as "portable". Meaning it had hand lifts on the side. Very loose definition indeed.
BurnItDwn
26,353
1,861
There is a lot of misinformation here and a lot of information.
This is really very simple.
A horn is sort of shaped like a bell. It's the shape of the thing that noise comes from.
A monitor is a speaker for monitoring the sound.
A bookshelf is a speaker that will fit on a bookshelf. Not designed to sit on the floor.
slightly more details below
driver = the thing that makes the noise (tweeter, woofer, midbass , it's that paper or foam or metal thing that actually has the magnet and such to make the sound.)
Horn = one possible shape of a driver (literally, like a horn. I have some speakers with horn tweeters. My brother's Guitar amplifier has a pair of horn speakers (full range).)
Monitor has nothing to do with size or power. a stage monitor is a speaker that a musician would have on stage to hear what the outpout sounds like. A Studio monitor is a speaker that essentially reproduces the sound close to reference so that the guy doing the recording or editing or whatever can monitor how it sounds.
A bookshelf is simply any speaker that is designed to be placed on a bookshelf. In general any speaker that is not floorstanding, and explicitly designed only to be mounted to a wall is a bookshelf.
vshah
19,003
24
not exactly. A horn is something a tweeter is mounted in. usually a compression driver instead of something more exotic, but you can, for example, have a horn loaded ribbon tweeter as well.
BurnItDwn
26,353
1,861
Horns aren't only for tweeters though.
Number1
7,881
549
Horns in audio: A wave guide mounted to a driver to amplify the sound.
here we have a pair of bookshelf speakers with horns mounted in front of the tweeters.
