Hooking an XLR self-powered sub to a home-theater type receiver?
sdifox
98,781
17,252
Your receiver has a sub pre-out. All you need is a single ended to xlr adapter.
http://www.amazon.com/Hosa-GXM-133-F...e+ended+to+xlr
Never mind, just read the manual on your receiver, it does not have pre out. Image search showed me a picture with pre-out...but that is the Thai model...
Check the back of your receiver to see if it has the sub pre-out like this one.
Edit 2. Checked the Thai website, it's the 552 that has pre-out.
Http://www.google.ca/search?q=onkyo...AQ&biw=1024&bih=768#biv=i|1;d|_GVS_E9hNNnUIM:
TridenT
16,800
45
Yep. I don't have a pre-out. Like I said, speaker wire is the only out that I saw.
TridenT
16,800
45
Anyone see any problems with doing 1/4" to Y-split RCA to XLR from one port off the y splitter?
sdifox
98,781
17,252
Err, what are you trying to do? Thought your source is powered? You need to bring it down to line level and just feed it straight to the sub.
TridenT
16,800
45
We use a mixer before we feed into the receiver. I'm just going to split the 1/4" outputs at the mixer and feed one to the receiver and the other to the subwoofer with a RCA to XLR adapter. Seems to make more sense.
It'll go from L-1/4", R-1/4" to L-Y-Splitter-RCA, R-Y-Splitter-RCA. L, R, RCA to RCA (for the receiver) and L,R, RCA to XLR to subwoofer.
I think that will work.
sdifox
98,781
17,252
Err, how are you going to do that with say two different HDMI sources?
sdifox
98,781
17,252
There is no video... This is purely an audio setup. We plug into the front of the receiver with RCA.
OK... so everything is fed though the one analogue input? If so, grab a mixer with two output, one to receiver, one to sub. Your sub can handle full range input.
