It works fine if I connect all computers using 1 router. However the problem occurs when I use 2 routers (the second one is my old router I am using as a switch).
I can't view the homegroup pc 1 (the main pc in the house) from pc2 (connected to old router that is being used as a switch). However I can view PC2 from PC1.
Also, If I click on networks tab, I see PC1 from PC2 but not under Homegroup tab.
My Laptop, that connects wirelessy using Router 1(main router) can see PC1 also.
Please let me know if you need any clarification. I don't think I have done a good job explaining
Should I just stop being cheap and get a switch or is there a solution to this?
Thanks
Thanks
