Homebrewers
I have all the equipment but haven't made any in years. I actually made some very good stouts when I was into it. If I ever get my garage cleaned out I may start again.
Hmm, I have to get a system running for our lab in the next week or so. 😀
It's been about 8 years since I last brewed, so my experience is essentially zero, again. I've been digging up recipes and wanted to jump into full-grain, but I'm thinking it's best to just go to our local supply and do a mostly extract, simple brew just to get things started.
The beauty is that I have access to a huge glass wash and autoclave 🙂, so sterilization is not a problem.
I want to do a winter bock for the first batch. Anyone know of a recipe like this?
and where you been OP?
It takes a considerable amount of ice to start with ice water from the beginning using an immersion chiller. I tried it once and we used almost 10lbs of ice trying to get to pitching temp. Doing it my way takes advantage of the ambient water temp until it's no longer efficient and only then uses ice. Doing this I can just dump the ice tray from my freezer into a bucket w/ a gallon of water and recirculate. I've found that starting around 100F will end up equalizing in the mid 60's.
For reference, my tap water in the summer comes out around 80F.
For chilling I've always done the opposite of what most of the kits have you do. Granted, if my tap water was as hot as yours it would be impossible. Rather than using copper tubing to pump the wort through an ice bath, I bought my own copper tubing and got a hose connector and I pump cold tap water from outside through that.
I felt this was more sanitary as I do not have to worry about any contamination from the inside of the tubing. In addition to this I usually manage to chill the wort to the correct temperature in under 15 minutes because of both the ambient water temperature in my area as well as the pressure that I get through the hose.
I haven't in about a decade, it's just too time-consuming and I don't drink beer much any more anyway. I usually stuck to simple ales, usually IPAs - I like hoppy beers and they didn't require the trickier temperature maintenance that lagers did. I still have a couple of hops plants that yield cascade and northern brewers though I don't take particularly good care of them and it's been very dry around here lately so their yield is low.
Most of my batches were pretty good, several people said they were they best beer they'd ever had but I was never blown away. One batch I brainfarted and used too much malt - I ended up with a very high alcohol content (almost 15% IIRC). I hated it but my brother-in-law couldn't get enough of it and took the remainder from me.
I use to homebrew beers, ciders, and sparkling mead, but when I moved into an apartment I gave away all my equipment. Now that I have a house I'm about to start again. I am in the process of deciding what equipment I want to use and will hopefully get a beer in keg by Christmas and a gallon of mead in bottles by New Years Day.
If I do start up again I want to try and do the whole process including mashing. That is when you can really customize recipes to taste.
That's exactly what an immersion chiller does. I just drop the copper coil in the boil for the last 15 minutes to sanitize it.
I don't use a counterflow chiller, which would pipe the hot wort through a copper tube surrounded by a hose pumping cold water.
Me and a buddy do it and have been getting pretty serious.
I just got a couple of kegs from a brewery we do work for. The valves on the top were shot, but i was cutting the tops off anyways.
Full grain with an igloo cooler for me.
Like most have said, its fun, but buying good beers from the store ends up making it about a wash in terms of price.
Your local brew supply store will sell a kit to get you started. If there's no one local, try brewyourownbrew Home brewing is an excellent hobby but, you don't save any money over buying good beers in the store. The thing I like is learning about techniques and the amazing variety you can create from 4 ingredients. Once you've had a good home brew, you can never go back to mass produced crap. Your tastes will also change with regards to malt and hops because as with any food, it's a learned experience.
Good to know. Over the last few years I've gotten heavily into microbrews...in fact, that's all I can stand to drink now. Texas has some really top notch breweries.
Thanks for the info, I'm pumped 🙂
Erm, you're right, I don't know how I got confused on that one. It seems to be that immersion is more popular than it used to be, but the pricing seems far more expensive than I remember it being. Has the price of copper gone up or something?
The price of copper is up. Just buying straight up copper pipe at Home Depot and making your own immersion chiller is a good $50.
Yes, yes it has. You've heard of copper thieves, no?
Might start as a hobby soon. I've looked into it before but never did it.
Go to your local brew shop supplier and check for classes. Most offer classes on different brewing techniques at least once a month. It's an easy way to see what's needed, time involved and, the chance to talk to other new and experienced brewers.
I homebrewed for many years, but have not lived in a place that is conducive to brewing in years. I have also been a BJCP beer judge for over 15 years. My rank is National.
Word. I'll check what's available when I get out to Arizona.
Sidenote: Karbach brewery down here has put out the first of two Christmas Ales, the first being 'Yule Shoot Your Eye Out'. Very crisp, with hints of nutmeg and other seasonal spices.
Keep an eye out for 'Fragil-e', which will be coming out in the next couple weeks 🙂
Respond to my IM. Karbach is a good brewery, I volunteer out at No Label in Katy.
Wonder if they get any distribution out to Austin, always looking to try beers I've never had before.
I just popped the tops on our Holiday Ale and White House Honey Ale that have been patiently waiting for 6-7 weeks. They are mighty delicious. The holiday was a kit and the White House was the recipe that got us back into brewing.
Both are good but I think I like the WH Honey Ale a little better.
Anyone else make a special brew for the holidays?
Haven't had a chance to brew this year, but I got my keezer built. Hopefully in March I can get my first brew going.
I need to take some time to post the 2 lab brews that we have now finished--bottling the Pale Ale this week, which we decided to dry hop when transferring to secondary.
More details later.
I don't think HomeBrewerDude posts here much anymore but that guy makes a top notch beer. He brought several nice kegs to YoYo's wedding and they were fantastic! 🙂
