LordSnailz
Everyone is suggesting to slowly build up the system vs getting a HTIB, but with $500, what's more important the receiver the L/R speakers?
Originally posted by: whattaguy
I never regretted purchasing my Paradigm Titans and Atoms. Awesome speakers for an affordable price. If you're lucky, you could purchase the Titans for <$200 and the Atoms for <$150. I built my system over a couple of years, and it's still going strong today (7 years later). I have not regretted being patient with the system.
Save some money and buy quality components. Remember: buy cheap, buy twice.
Link to Titans?
Link to Titans?
http://www.paradigm.com/Website/SitePar...odels/Performance/PerformanceSpecs.htm
Budget Proposal
1) 600 receiver
2) 200 center channel speaker , imho this is the ost important one
3) 500 L and R front speaker
4) 500 Powered Sub
5) 200 L and R rear and LR side(7.1)
Budget Proposal
1) 600 receiver
4) 500 Powered Sub
So would $1000 for a good/decent receiver and LR front speaker and center channel even be possible?
Budget Proposal
1) 600 receiver
4) 500 Powered Sub
Originally posted by: lancestorm
$1000 L/R Klipsch Reference 35 (they might be cheaper than that, that is list)
http://klipsch.com/product/product.aspx?cid=633
500 H/K or Denon receiver
20 cables (any standard copper --- I'm in the wire-is-wire camp)
Originally posted by: NTB
Check this out:
Onkyo HT-S780 HTIB
The older versions of this setup from the last few years have recieved some pretty good reviews. Do a google search for Onkyo HT-S760 and HT-S770. I almost bought one of these, until I decided to build my home theater a piece at a time. Don't really have anywhere to go with the surround speakers at the moment. I still ended up buying the reciever from the HTS-760: an Onkyo TX-SR501. Works beautifully.
Nate
Check this out:
Onkyo HT-S780 HTIB
Nate
Yeah i looked at those, and thats more along the lines of what i was originally talking about, right in there at the 500$ budget
I just spent 2700 on a tv all said and done, and was looking for something that would be good, for a few years, until i save up some more money.... Im more of a bang for your buck type guy, I try to get the most for my money. The 2700 tv was on sale from 4700, and was only available at that because they ran out of the lower level model they had at the special price, and bumped me up for free
Originally posted by: CondorHero
forget what everybody in this thread is saying, you should just get one of those setups for like $100-$200 (I think the panasonic is on sale at cc). Anyways, to compensate for any percieved poor sounding quality, just turn up the volume on your system, it'll make it sound better.
Originally posted by: teckmaster
pick yourself up a JVC TC-4 OR TC-5.
It's a home theater in a box. 5 disc dvd/cd player, am/fm stereo, and rca's to hook something else up to it. Its also a 1000watt setup either one you buy. We sell them where I work, and I'm trying to get rid of my component setup so I can get one. Awesome sound and deep bass. Should be able to get one for around $350.
Originally posted by: RayH
For under $500, one other option is to pick up an amplified 5.1 system with decoding like the Logitech Z-5500 which can sound better than most HTIB packages and for cheaper. You can still slowly upgrade later and "downgrade" the old system to the pc. There are alot of good reviews of it on the net. I went with buying used high components for my system but had gotten the older model Logitech Z-680 for my parents and it sounds great in their setup. Can even be cranked fairly loud without distortion.
