YOyoYOhowsDAjello
Moderator<br>A/V & Home Theater<br>Elite member
- Aug 6, 2001
- 31,205
- 45
- 91
Looks sweet tfinch2
I haven't done it myself yet, but I've read that if you add a black boarder around your image, you'll perceive it as having better contrast and the image will look better overall. When I get my screen set up, I plan to make a boarder for 16:9 and then inserts that I can add when I'm watching a 2.35:1 movie or 4:3 material and have the boarders line up with the edges of the image.
As for real speakers vs logitechs....
It's not like there's anything magic that takes place when you move to HT speakers vs. computers speakers. It's still an amp getting a signal and amplifying it to some paper (or some other material) cones that vibrate
. I'd have to say the things I appreciate the most are
1. Better response over a fuller frequency range (I get about 15Hz to 20kHz +/- 5dB) meaning I get a lot more low end (I think most computer subs... even "THX" subs only go down to about 35Hz) and sets like logitech that don't have tweeters don't do a great job on high stuff
2. Better clarity and richness of sound, especially at higher volumes
3. Well... higher volumes
with a surface are of drivers of over 300 square inches, it's a lot easier to get more air moving in a room compared to your average set of computer speakers
4. More options - you get to pick how much you want to spend on each component and decide what features are important to you - along with this is connectivity (related to receiver choice) allowing you to hook up a ton of stuff to the same set of equipment without a bunch of "ghetto rigging" you'd have to do with a set of computer speakers
5. Upgradability - when you want to replace something, you can just replace that one component and keep the rest - when I thought my Dayton 10" from parts express wasn't cutting it, I sold it to a friend for 75% of what I got it for and upgraded to something a lot better
