Home network questions
Eltano1
1,897
You can't go wrong with Linksys either (I'm using it along with a switch).
Eltano ;)
knutp
802
I really like smc. Good warranty, Cheap and good performance. I've used the nic's, switch's and routers without any problems.
A2KLAU
1,406
For my home network I am using ALL Netgear products. All the cards are duel speed, including the PCMCIA card, and the Hub is a 4 port duel speed.
At school out school network uses ALL Intel, apart from the extension hubs which range from the same Hub as mine to Linksys...
Personally I would got for Netgear. Its not too expensive and does the job well IMHO.
Good luck :)
Albert.
