Home Audio recommendations
luvya
Banned
Nov 19, 2001
3,161
get some less known brand for receiver....so stuff like yamaha and onkyo should be out of your list.
and no!! NO BOSE!!!!!!!!!!!!
Mark levinson, or some tube amp should be fine with ur speaker...but then again...might be out of your budget.
check out www.audiorevolution.com for review.....they have tons of review.
luvya
Banned
Nov 19, 2001
3,161
have you try dynaudio(maybe spell that wrong) speakers?
I thought they sound pretty good and price resonably.
Viperoni
11,084
<< have you try dynaudio(maybe spell that wrong) speakers?
I'd guarantee that Dynaudio's (like the Audience or Confidence series) are better sounding than ANY Paradigms out there. I don't trust plate amplifiers (unless truly good ones like Adire Audio sells.....they have built in user selectable active crossovers).
Madisound Soloist kit - Scan Speak drivers
Madisound Eton 11.2 kit - Eton drivers
Madisound Dyanudio Twynn's - Dynaudio drivers
auyong
Banned
Nov 29, 2000
431
speaking of tube amps, maybe you should check out some Golden Tube amps. I auditioned my friend's system and the music is schhhwweeett!
teriba
1,130
Speakers:
Bad brands:
Klipsch are only good in the computer speaker market, not home audio.
Good brands:
B&W (the best in the world, easily), Dynaudio, Paradigm
As a general rule though, you pay for what you get. Spend as much on the speakers as the rest of your setup combined. In this example, that means $2500 for speakers.
Get a solid pre-amp and 2 channel power amp. Any CD player will do as it is the least important in the chain. THD's in CD players range between 0.01% and 0.001% which is inconsequential to the 1-10% THD in speakers and .01% to 1% in amps.
I love NAD electronics, check out their Signature Series. Nakamichi, Denon, Harman Kardon are pretty damn good too. Carver are expensive but very gutsy.
The best rule is the stay away from integrated components.
cd->preamp->amp->speakers
If you can afford it:
cd transport->cd d/a convertor->preamp->amp->speakers
Viperoni
11,084
A nice rega planet 2k cd player running to a tube preamp (DIY perhaps? The bottlehead.com Foreplay is only $150), and a nice amp (maybe something tube as well?)........
Goi
6,771
7
You really shouldn't be asking for home audio advice on the Anandtech forums...its really the wrong audience. Try Home Theater Forums or AVS Forums for advice.
Anyway, here's my take for a basic 5K system.
Paradigm is a pretty good system, as is PSB. Great value for money. With 5K, you could go with their flagship reference and Stratus lines respectively. Personally, I prefer the sound of PSB after auditioning both.
Paradigm Reference Studio 40 - $900
Paradigm Reference Studio/CC - $400
Paradigm Reference Studio ADP 450 - $800
Total Price - $2100
PSB Stratus Mini - $900
PSB Stratus C5i - $400
PSB Image 2B - $300
Total Price - $1600
*Edit* Forgot to include the sub...no wonder I wasn't hitting $5000 yet with some of the combinations :)
For subs, the best price/performance are SVS and Hsu Research subs, although SVS has a larger following. A lot of people swear by them. Since you'd be more concerned with music, you won't need the most badass sub in the world, and their entry level subs should do pretty well for you:
SVS 25-31PC - $669
SVS 20-39PC - $749
Hsu Research VTF-2 - $500
Hsu Research TN1225HO w/250W amp - $709
The Dynaudio advice was also good, provided you have more money. Dynaudio's Contour series impressed me a LOT, but their entry level Audience series, which is what you would be looking at with your budget, failed to impress me as much as the Paradigm and PSB flagships.
Another brand you could be looking at is Diva by Swans...they've been widely heralded as the best bang for the buck speakers around now, but they're an internet purchase only brand, which makes it more risky. If you find out don't like the sound in the end, it'll be more troublesome to return.
As for amplification, a good receiver would probably be fine. I'd recommend the Denon 5800 or B&K 307, but unfortunateely your budget doesn't allow for that. Next down the line, Marantz receivers are probably your best bet, as they have been widely noted for their musicality, which is what you're looking for. The Denon 4800 is another choice within your budget. Your budget doesn't allow for a decent separate prepro/power amp setup, so look for a good receiver instead.
Marantz SR-18EX - $2500
Marantz SR-19 - $1700
Denon $1500
As for the CD source, Viperoni made an excellent suggestion. The original Rega Planet was already very good, and pretty cheap too. The Rega Planet 2000 is an improvement to that, and is only marginally more expensive, so you shouldn't even consider the original. Rotel and Marantz also make very good CD players(Marantz has the KI Signature line and O.S.E series which are tweaked versions, supposedly noticably better than the originals, but I've not heard them personally)
Rega Planet 2000 - $800
Rotel RCD-951 - $500
You didn't mention a DVD player though, so I'm wondering how you're gonna watch a DVD at all, much less 2? :)
Perhaps you should invest in a DVD player, as it will also be able to play CDs, albeit perhaps not as nicely...or even better, get both :)
Cable wise, don't spend too much on boutique cables. What I'd recommend for interconnects would be Belden cables(89259 for analog, 1506A for digital coaxial) along with some good true 75ohm connectors(Canare locking, or some WBT clones). They are broadcast quality and MUCH cheaper than the popular boutique cables. Monster cable is ok, but really very overpriced for mediocre performance. For speaker cables, generic 10AWG or 12AWG OFC speaker cable from homedepot would do. For short runs, even 14AWG or up to 16AWG would do without much noticable difference.
So, mix and match the above to get a sub $5000 system that would sound REALLY good, good luck and enjoy! :)
Texmaster
Banned
Jun 5, 2001
5,445
<< Tex, nice system :)
But why are you going with (what appears to be) digital cable, rather than satellite? Much better picture and sound for that excellent equipment!
Pointed the wrong way for the dishes my friend :(
Texmaster
Banned
Jun 5, 2001
5,445
<< LOL, Mort Kondracke, Liberal, on Tex's TV. >>
hehe Ah Mort's a good guy. I might even call him a demcorat :)
John
Moderator Emeritus<br>Elite Member
4
I had a 5K budget for my home theater as well, but I went over by a small margin. I spent a lot of time on the Home Theater Forum searching thru various posts before making a decision.
Denon 3802 - $750
JVC SA70BK progressive DVD/DVD-A - $275.00
Klipsch RC3 II, RF3 II, RS3 II reference speakers- $1300.00
SVS 16-46PC subwoofer- $850.00
Sanus rear surround stands - $100
Salamander Archetype 5.0 audio rack- $175.00
Hitachi 53UWX10B HDTV - $3000.00 w/ 5yr warranty
Acoustic Research Pro series cables - $300.00
IXOS gamma wire for the front speakers - $75.00
Dayton Audio bannana plugs - $60.00
I purchased the speakers and TV from a local dealer. I will finish hooking everything up tomorrow, wohoo!! ;)
