Originally posted by: acemcmac
bump
Originally posted by: MS Dawn
PIP system with setback options FOR THE WIN BABY! :laugh:
Originally posted by: FrankyJunior
THe more time it spends in the lower setting the more money you save. You should set it to drop down an hour or so before you go to bed. Unless you live in the drafties house around, your house should still be at a decent temperature until you go to bed.
Mine goes down at 9:30 and I'm in bed around 10:30 most nights and the temperature inside is the same or maybe 1 degree less.
Originally posted by: Citrix
now all you need (and me) is zone heating/cooling. its where ducts in each room have luevers and sensors to control the heating/cooling for that room only.
say in the summer a room on the west side of the house is hotter than a room on the east side, the A/C will kick on and the system will close all the vents in the rooms that do not need cooling but open the room(s) that do need cooling. saves money from not heating/cooling the entire house. but those systems are expensive but in the long run i can see how they can a boat load of cash.
Originally posted by: psydancerqt
mine's set to go 1 degree cooler when we go to bed. it used to go cooler when i went to work, but i work at home now... taking care of the baby
Originally posted by: j00fek
can you update with a savings amount from when you upgraded?
Many homes use heat pumps. Heat pumps = ~80% of the heating/air conditioning is free and the remaining 20% is electricity that you supply. The key with heat pumps though is that they can't quickly change temperatures, especially in extreme weather. If you have a very cold day and have your thermostat suddenly change from 62°F to 72°F, the heat pump can't handle that change. So, emergency heat will kick on. You now pay for nearly 100% of the heating cost. Your heat bill went up by a factor of 5.Originally posted by: Marlin1975
That and they can get had for $25-40 very easy so I don't know whay they are not installed when houses are upgraded/built now.
Originally posted by: Thraxen
How long did it take to put that in? We don't have a programable thermostat, but I think I'd like to get one. The heating and air guys always charge waaaaay to much though so I'd to do it myself.
Originally posted by: swtethan
It's pretty easy to put in a programmable thermo, shouldnt take you more than 10 mins, its like 2 wires.
How long did it take to put that in? We don't have a programable thermostat, but I think I'd like to get one. The heating and air guys always charge waaaaay too much though so I'd like to do it myself.
Under ten minutes. It was the fastest and easiest home improvement project I've ever done, tied with changing a two pole light switch for a two pole led backlit light switch.
Radiator. No go.
Radiator. No go.
radiator? uh??? im not talking about radiators.
Radiator. No go.
I have radiators. When you have radiators, you can't exactly put levers in the ducts because there are no ducts. Sorry for not clarifying. Believe me, in a three story house, I'd be all over that if I could...
