*Qualifier : Unless you're under warranty - then do it whenever the recommended maintenance schedule says to do it.Originally posted by: Skoorb
So how many miles total 10 or 12k? Probably fine. MANY new cars recommend this. Especially with your miles at highway mileage it's a fact that you are simply flushing money away changing it every 3k anyway. Go with what you manual says. It doesn't say 3k.
Originally posted by: Mermaidman
Has anyone personally experienced an engine that was confirmed to be damaged by infrequent oil changes? What are the signs and symptoms?
Originally posted by: rh71
general question - if you do a lot of local, non-highway, driving, does synthetic hold up well or better? Should I do changes more frequently anyway? At this rate, it'll take forever to reach the mileage intervals so not sure what to really go by.
Originally posted by: fleabag
Well I'm thinking it's possible to go like 50K miles before an oil change w/o destroying the engine if you were easy on the throttle and all you did was cruise on the highway with not so frequent cold startups, had the car always perfectly tuned, etc. Most of the reason behind needing to change the oil is because of the excess carbon buildup from incomplete combustion or even complete combustion winding up in the fuel. That's why they usually say change your oil X number of miles or every 6-12 months etc. Cause one person may only drive 1000 miles in a year (unlikely) but most of their trips are less than a mile long.
Originally posted by: JSt0rm01
What if you are looking at cars that have been sitting for some time with oil? say 3 years with 3000 miles total driven in that time and no oil changes (grandma cars)? Run away no matter the deal? Can this be fixed by changing the oil regularly after something like that?
My female cousin drove her new Civic for 56,000 miles before an oil change. She didn't know she had to change the oil in a car. The engine and the car was fine.
