hmmm... too high??
brazzmunk
187
i got winchester running stable at 2.66 BUT i'm running 1.625v (14% increase) temps are
51 load 45 idle... DANGER zone?
GuitarDaddy
11,465
You must mean your using the 1.625v setting in bios? If so thats fine, if you check CPUZ or AI booster it should show 1.57-1.60 which is the max the board will give for CPU volts. The same result can be acheived using the 1.55 setting in bios 1004. I have been running the max setting on this board since december with no problems, as long as your load temps (prime small files for a couple of hours) doesn't go over 60c your OK IMHO.
ts3433
2,731
I've heard 1.6V might be questionable, especially on air, but might not be a big deal with water cooling.
