I wouldn't go above 1.7v actual, and make sure you see actual and not what is set in the bios...i am sure you know that anyways but I will post it for newbies....I actually don't go much above 1.6v now as it usually only garners 3-4 fsb max and not always worth it for the voltage and the added heat....
