High Resolution?
Mar 19, 2003
18,289
Originally posted by: Cygnus X1
My Dell 19in M991 CRT will do 1600x 1200 at 72refresh rate. But I can never equal out the fonts readability. Any help would be appreciated with size tweaks. Size does matter you seem to say. I like to game at the same resolution as my desktop is set. Is that lame to think that way?
In my opinion, 1600x1200 is a little high for a 19" CRT (and 72Hz is lower than I'd want to run on a CRT too). I used to have a 22" CRT for a little while and found 1600x1200 (either at 85Hz, or all the way up to 109Hz) to be the best resolution as far as "size" of the pixels on that size monitor. 1280x960 would probably be good for a 19" CRT.
JimmyH
182
12
Low rez will always be an advantage w/ online fps. Not just the high fps but varience in fps when the action gets hot will ruin your aim. Given your 6600gt, you outta consider 6x4 or 8x6 w/ low settings, no AA or AF for maximum competitiveness.
Cygnus, what rez did you run q3dm17, the longest yard at? ;)
gac009
403
Originally posted by: BrokenVisage
Originally posted by: archcommus
I have a 19" LCD with a native res of 1280x1024 so I just run all my games at that. Looks great, especially with some good AA. Because I never exceed that res I see ultra-high end video cards as completely unnecessary to me. For example my X800 XL runs Q4 no problem at my LCD's native res with max everything.
Wow, as a X800XL owner I have to call shens on that. To get nice, sustainable framerates in Q4 at 1280x1024 I really need to sacrafice quality. Medium settings all around, no AA, no AF. Please tell me your 3dMark05 score and how OC'd your card is.
I run Q4 at max settings, 4AAA and 8AF 2 1280*1024 and never go below 30fps. I went into my config file and turned on caching, and set it to 196mb for caching and 2024kb min. file size. I ususally stay at 60fps and 30-40ish in firefights. This is only for the first few hours. I turned off the fps as it was annoying me but it runs the same as far as I can tell for the rest. This is with the system in my sig.
In fear I have to turn most things to medium and run it at 2AAA and @1280*720. I just pretend that I am playing fear on a 17'widescreen monitor :p
Matthias99
8,808
Low settings can help if you want to maintain good framerate, but at 800x600 or 640x480(!), the display is so blocky that it becomes difficult to accurately pick out targets at range. And that's NOT good for competitiveness (or at least for my general playing abilities). This isn't *so* bad in CS, since the maps are relatively small (so you're rarely engaging anyone at super-long distances), but in a game like Unreal Tournament [insert version here], it can make things difficult.
A 6600GT shouldn't have any problems with CS:S at 1280x960 or even 1600x1200, as long as detail settings aren't cranked all the way up and AA/AF are off.
Jeff7181
18,368
11
I play online shooters, CSS, BF2, UT2K4, I have tried higher resolutions and it will work but why try it if I seems to get more kills and looks just as good.
I have a Dell crt 19in M991, and recomended is 10x7 but I find if say on CSS I play at 600x800 and turned up all to max reflect all, 4X aa, 16X af, it looks great!
Maybe I need a new monitor to truely show 1600x1200, because If I use that I can't read anything on the screen. Do native 1600x1200 show the letters normal, readable size without having to tweak every font and dpi?
In short I can either play at 800x600 or 1078x800 with all max or take the eye candy off and play at uber high resolution. What is the point in that? I have ready that most fps shooters play the 800x600 just for more kills, are these uber high resolutions really necessary?
Maybe I need a new monitor, than I'll shut up. I really do like to be able to read web pages at 800x600 is best 1078x800 is good to, but anything higher is nuts.
What are u a little girl? Not even 1600x1200 is enough for me cause AA SAMPLES are never as good as real pixels which contains detailed textures.
2d images and games are bigger at a lower resolution or smaller at higher resolution, that's why you see them bigger DUH, 3d realms are much different the higher the resolution the less ammount of jaggies u'll get.
Didn't have your coffee this morning?
gtx4u
Banned
Sep 8, 2005
272
I don't like ignorant people, and I don't drink coffee.
The resolution thing is so simple, I don't understand how people don't understand it.
gtx4u
Banned
Sep 8, 2005
272
and btw coffee can't solve problem, beer and money can.
Yanagi
1,678
Get drunk, buy hooker FTW?
gtx4u
Banned
Sep 8, 2005
272
Originally posted by: Corporate Thug
so what would look better:
1600*1200 0aa/0af or 1280*1024 4aa/16af????
Stop bashing high resolution u ass-wipe with weak sh1t, 1700x1280 2x AA and 8x AF's performance equal to 1360x1040 4x AA and 8x AF in Doom 3/Quake4, this is a fact I've tested my self with the game, and quite frankly they both look the same in some situations, but I like 1700x1280 more my self because it looks better when I try to look into some 1s face far ranges.
gtx4u
Banned
Sep 8, 2005
272
I never gotten drunk before, and I never been with a hooker, not sure about you though.
I guess the word "Hooker" poped on ur mind because you've been with so much of them.
sundev
1,092
Stop making up resolutions please... kthx.
gtx4u
Banned
Sep 8, 2005
272
Hey ignorant ever heard of nVidia screen resolution and refresh rates panel? It allows you to add custom resolutions of your choice. Stupid people :roll:
http://img358.imageshack.us/my.php?image=add13pb.jpg
sundev
1,092
omgur2kewl.
Everyone knows you can use custom resolutions. But you are acting as if the resolutions you are stating and using for comparisons are what everyone uses. No one cares if 1700x1280 with 2xAA is equal to 1360x1040 with 4x. Besides, those resolutions aren't even the correct aspect ratio, hence they are MADE UP.
gtx4u
Banned
Sep 8, 2005
272
Alright u know what I used 1600x1200 2x AA vs 1280x960 4x AA which is the perfect 4:3 aspect ratio, guess what their performance is still just about the same.
sundev
1,092
Interesting.. sounds about right. Which game was this? Regardless I would prefer the 1600x1200.
gtx4u
Banned
Sep 8, 2005
272
omgur2kewl.
Ur right, every 1 knows, but YOU didn't until, I told you. And no 1 cares about what you have to say because U havn't said a single helpful thing in this thread.
OMG ur either too stupid or retarded to realize my point, all I was saying is that High resolution + 2x AA is equal to low resolution + High AA in performance or better performance in some minimum framrate situations, and quite frankly it's always better to run at a higher resolution.
And sometimes you don't always need 4:3 aspect ratio to play Mr. omgur2kewl kthx, why do you think 1280x1024 exist for for game playing even though iz 3.75:3 aspect ratio and not 1280x960 which equals to perfect 4:3.
gtx4u
Banned
Sep 8, 2005
272
Doom3/Quake 4 can run at any resolution u want it to run u have to modify the autoexec.cfg, Source can run at almost any resolution, F.E.A.R can run at any resolution too if you know how.
I'm gonna test F.E.A.R. and post some screenshots just to shut ur ass up little stupid boy.
flexy
8,464
155
i dont even remember when i playes something at 800x600...must 've been in the late 80s or so.
imported_michaelpatrick33
2,364
Originally posted by: pulsedrive
Hell, I run all my apps at 1680 x 1050. It all looks gorgeous on a 20" widescreen. So I don't know why you would have a problem with 1600 x 1200 on a 19" CRT.
QFT
except I am running at 1920 X1200 :D
I love it myself. I try and game at native if I can but going down to 1600 X 1200 on the 2405fpw doesn't degrade too badly. I haven't really tried 1024 X 768. I guess I could ...
DaveBC
526
Originally posted by: CP5670
You could say that. :p One of the big advantages of a CRT in my opinion is that you can have the Windows resolution lower than your maximum resolution for games. Unfortunately, I have to live with a headache inducing 1400x1050 on my 14.1" laptop LCD. :p
My monitor has LCD-like sharpness at 1600x1200 and still looks very good at 2048x1536, but the text size becomes too small at either resolution (the viewable area is 20"). You can increase the font size or the dpi, but that only affects some of the text and can cause things to get misaligned. The dpi setting also had a weird effect on IE and Firefox on my laptop, causing all the graphics to get pixellated for some reason.
Same with my LCD, My desktop is keep at 800x600 and all my games are at 1280x1024
jiffylube1024
7,430
No need to kill the AF! It barely has an impact on performance...
With that said, I'd probably go for the 16X12 one, if for no other reason than because it's basically my LCD's native resolution (1680X1050), so it will look much better to run it @ native res with no AA than to run it at a lower res with AA.
Besides, you can usually enable 2x AA with virtually no performance hit and that will get rid of most of the edge crawl, which, combined with the increase in resolution, will probably look better than the lower res with 4X AA anyways...
For once I agree with gtx4u. I personally have just found higher resolution to look better than lower res + AA. Definitely keep the AF on though; otherwise the textures look like crap once you look in in the distance...
Greenman
22,497
6,582
omgur2kewl.
Ever hear of anger management?
Oh, and a small tip for you, no one is impressed at how tough and smart you think you are, in fact, when most of us read the things you write we tend to ignore you because you present yourself as being somewhat stupid and arrogant. I'd like to think thats not the case, but that is how you come off. I'm not sure why you feel the need to insult someone because they dissagree with you, but I assure you, every time you do it the value of your opinions is reduced.
xtknight
12,974
I don't know what his problem is either...
Look at the end of the page linked below, it's pathetic really but not as bad as what happened in this thread.
http://forums.anandtech.com/messageview...&STARTPAGE=2&FTVAR_FORUMVIEWTMP=Linear
