SerpentRoyal
Banned
- May 20, 2007
- 3,517
- 0
- 0
The heat sink is metal, so metal nut is fine.  You don't need to add washer at the top.  70C is fine for PWM.  Problem with IP35 is that the NB and PWM share the same heat sink.  Heat from the NB will elevate the temp at PWM.  IP35-E does not have this problem because it uses two separate heat sinks.
More clamping force may not improve temperature unless you have a fan blowing over the MOSFET region to lower the temp.
Others have seen 62 to 65C PWM with IP35-E and oveclocked 6600 quad.
 Facebook
Facebook Twitter
Twitter
