Greetings,
I'm in the process of accumulating parts for a Home Theatre System. Ideally, I would like to consolidate my personal computer and the mess I call a home theatre into a minimalistic setup that doesn't skimp on performance or aesthetics. I've spent a long time deliberating on the parts and components and now I'm looking for some more objective advice on the setup. Feel free to pick this apart...
Concerns
a. Need a minimum of 750Watts for this setup
b. Silverstone Strider 1kW PSU is the biggest (size😛ower) this case will accomodate
c. Uncertain about the quality and durability behind the Strider series of PSU's
d. Cooling capacity with the dual 80mm Black Ice II Micro Radiator
e. Zalman's HD160XT compatibility with Vista Media Center
f. CLabs X-Fi XtremeGamer Sound Card versus Built-in Supreme-FX Sound Card
g. Display quality and gaming capacity on a 40" 1080p Display (Need SLI setup...?)
h. HDMI to DVI converter: any degradation or limitations with these converters?
Components
Zalman HD160XT HTPC Chassis
Silverstone Strider 1000W
Asus Striker Extreme
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz
Geil 4GB (4x1GB) DDR2-1000 PC8000
WD Raptor X (x2)
EVGA GeForce 8800GTX ACS3 768mb SLI
Creative Labs X-Fi XtremeGamer
Lite-On DVD+/- 20x Burner SATA (or) Samsung DVD+/- 18x Burner SATA
Water Cooling System
Danger Den Black Ice Micro II Radiator
Laing DDC-1 Ultra Pump
Reservoir (Anything that will fit)
Danger Den 8800GTX Water Block
Danger Den TDX LGA775 CPU Water Block
Display System
Samsung 1080p 40" LCD (Primary Display)
Samsung 226BW 22" LCD (For Privacy)
Audio System
Bose Lifestyle 38 (Represents best combination between size and performance)
Regards,
Pacal
Concerns
Components
WD Raptor X (x2)
Display System
Audio System
Regards,
Pacal
