High end audio for home theatres Over a $3000 Unit With built in LCD
Amused
57,409
19,796
Originally posted by: FiLeZz
why would I plug anything into my system that was s-video or Composite Video.
Just asking.
Due to I never have.
I always use DVI.
or VGA
Then why buy a preamp with video switching at all? Or at least, without video switching for DVI? Why buy a video switcher with an LCD if you're not going to be running any video through it?
And I still have a non-HD DirecTivo and VCR I need to hook up.
FiLeZz
4,778
47
I just hate watching non high res things on a projector.
It looks all fuzzy.
If I want to watch tivo I do that upstairs.
I pretty much only use the theatre for Movies/HDTV viewing.
Goosemaster
48,775
This is acually an Audio 7.1 processor.. and a audio/HDTV video switcher
So, mine has a 6.1 Processor and HDTV switching...no biggie:D
Bass management adjustable 40/60/80/100/120/150Hz 12dB/octave (2nd order)
Nice bass management
Video bandwidth component <60MHz-3dB
Perhaps I am not reading that right, but that seems a little low for such expensive equipment. Okay, you only have two components so I guess that is fine. Still much cheaper stuff has more bandwidth. Hell, my cheap onkyo has around 50.
Transcoding of composite video to S-Video or S-Video to composite
I am guessing that that last words was meant to be component.
Looks like a nice preamp, but flashly more so that meaty.
....and the M&amp;K s150's for my Surrounds.
Mad respect. M&amp;K stuff is killer. I really am not too knowledgable on Fosgate amps though...
FiLeZz
4,778
47
The specs you are reading are on the FAP-t1
They have not posted Specs on the FAP-t1+ as it is really not out yet.
http://www.fosgateaudionics.com/products/index.asp
So we see.
Goosemaster
48,775
Basically, for that price you should be getting:
1) sonic madness...a myriad of processors and riciulous specs.
2)gadgets. Hell, if it already has an LCD that sort of puts you in the gadgets demographic. For this price you should at least get network connectivity.
Amused
57,409
19,796
It looks all fuzzy.
OK, my question stands...
Seems like a huge waste of money if all you're using is the sound processor. You can buy those alone, you know.
FiLeZz
4,778
47
It looks all fuzzy.
Maybe I did not relay well enough.
THE FAP-T1+ HAS HDMI THISis DVI
The specs and pictures for the most part are the FAP-T1 Not the FAP-T1+
So the FAP-T1+ does do DVI switching.
Amused
57,409
19,796
It looks all fuzzy.
Ah, OK! Forgive my ignorance then. :)
You have to admit it would have been really silly to get that if it only had component switching and you only used DVI. :D
FiLeZz
4,778
47
It looks all fuzzy.
Right you are. Right you are.
As for the LCD built on the front, no idea what I will use it for.
Some people use it for security camera monitor.. Bah a waste..
Amused
57,409
19,796
It looks all fuzzy.
Well, if you have the processor out of site of the monitor, I guess it could come in handy. It also doubles as a readout for doing stuff on the processor, right? It may make things easier to do when you set things up.
Jun 18, 2000
11,211
775
Ah, I knew it looked familiar. The CD-750 is a rebranded Infocus model. My work has a LP500 which is the same chassis, but with a 800x600 DMD. If the color wheel and optical system on the LP530 (Infocus version of your projector) is anything like the LP500, then it isn't very suited for a home theater.
Please tell me the projector is next on the list to upgrade!
What size and type of screen are you projecting onto? What is your throw distance? I can think of several models in various price points that would give you an upgrade over the Boxlight.
Apex
6,511
www.gotapex.com
It's missing the ability to convert composite and S-video to component. Something I like so I can have only one component cable running from my processor to my monitor and use only one input on my monitor.
This is generally not included in most good pre/pro's. There's always a quality hit when you convert, especially compared to dedicated scalers. Practically A/V pre/pro's have video switching though.
spidey07
65,469
Originally posted by: vshah
3x component input?! jeez what do they think you're gonna hook up to this thing!?
nice stuff
-Vivan
3 compent isn't nearly enough.
xbox, ps2, DVD, HTPC, game cube, HD, processor
that's 7 right there.
I use a lowly denon 3802 for processing only. arcam would be next purchase.
spidey07
65,469
Originally posted by: Apex
I've read some good things about that Fosgate unit.
I'm using a Lexicon MC-8B, a low/mid end processor (MSRP: $8k). I couldn't justify anything hifi with the amount of time I use my system. I love the way Logic 7 sounds over 5.1 and 6.1 source material, way more than straight DD, DTS processing, or DPLIIx, or THX. I also specifically looked for XLR out, since I wanted to use balanced connections between the pre/pro and my Adcom GFA-7807 7 channel amplifier, as well as Crown K2 subwoofer amplifier. The lower noise floor over standard single ended connections was definitely worth the premium.
Lexicon MC-8B Specs
Lexicon MC-8B Front
Lexicon MC-8B Rear
yeah, I'm kicking myself for not getting the super deals on the HK 8000.
mmmm...logic 7.
spidey07
65,469
Originally posted by: richardycc
what are the rest of the system?
I have 2 4100 Fosgate Audionics amps.. I will upgrade these after the Processor to the new 1000.5
5 channle amp.
I also have a 3000 watt Peavey amp running the Subs.
I have 32 12" subs Yes 32 subwoofers.
A DLP projector.
a samsung HDtv tunner.
Nice theater, very well done.
spidey07
65,469
Originally posted by: DaveSimmons
To me it seems silly to spend an extra $2K for only an inifinitesimal sound quality improvement over a Denon 3805 or comparable H-K. But if you've convinced yourself you can hear a difference, enjoy :)
heh, pre-amps have some of the biggest impact in sound...second only to room/speakers.
Goosemaster
48,775
Wow. I did not know that.
Apex
6,511
www.gotapex.com
The quality hit is going down, which is a good thing. Direct to your display is still the best, highest quality path though, unless you're doing scaling to match your display's native rate (if applicable).
