The Linuxator
Banned
"Hi Redhat, I hate you"
Hi n0cmonkey, I hate you and I don't need a reason for it 😛
Ok, maybe standard is the wrong word. Maybe I have to specify it as a historical standard. Tru64 is a fringe case anyhow.
Last I heard (recently, but in a dead tree formatted magazine) cifs wasn't done, and didn't cover all of the cases smbfs did so they were hesitant to consider smbfs as deprecated.
Just putty in this case. It was set to one of the MANY ISO standards (I can find the one it was set to previously, if you're curious).
IMO Tru64 is no more of a fringe case than any of the free BSDs or HP-UX, so why should one be given precedence over the other?
And as I said, the device naming convention is more confusing than the use of labels. /dev/sd*, /dev/hd*, /dev/wd*, /dev/dsk/c?t?d?s?, /dev/disk/dsk??.
I don't know what features are missing, I've used cifs with Win2K and Samba and it works pretty well. The big thing is that smbfs doesn't support files >2G by default and cifs does.
No need, I was just curious if it was a local terminal or remote. I've never had much fun with putty, UTF8 and things like ncurses either although I don't remember man pages showing up screwy.
I know that device naming and numbering is something that is fundamentally broken on Linux machines.
Then how should it be done?
Pointing out something that you think is a problem is one thing, but finding a solution that actually works well is another.
Basicly the problem is is that device names are determined by first come first serve. It depends on the order that the devices are detected. If you change something in the kernel or change how the hardware is arranged then probably you change the order that they are detected and thusly change the /dev name.
Driver "mouse"
Option "device" "/dev/input/mouse0"
I can go:
Driver "evdev"
Option "name" "Logitech Optical USB Mouse"
Otherwise /sysfs and udev (and hal I suppose) are the 'real' solution to this problem that Linux/Freedesktop.org people have devised. It's now nearly possible to use udev to set /dev/ names that remain consistant irregardless of this or that paticular configuration.
For harddrive and file system devices they have this 'EVMS' stuff that is being worked on that I don't know much about because Debian doesn't use it by default (although you can migrate your systems to it after install time)
I know, but it's not something easily fixed. There's no easy, programatic way to name those devices.
Driver "mouse"
I can go:
Driver "evdev"
Maybe. But then people will be complaining that when they plug in a new USB mouse at work it doesn't automatically works but if you use /dev/input/mice, it would have. And you lose the "treat everything as a file" philosophy that so many unix users like.
Originally posted by: drag
I don't know...
It's based on a first come first serve setup. It's a huge problem with USB devices.. for instance If I plug a mouse in first then my tablet then my configurations have to go:
/dev/input/event1 == mouse
/dev/input/event2 == tablet.
When I plug my tablet in first It goes:
/dev/input/event1 == tablet
Then if I want to play a game with my joystick then that makes the mouse:
/dev/input/event4 == mouse
And then don't even ask what goes on when I unplug my keryboard or try to use my trackball.
So thats screwed.
Now tell me what happens now in my server when I have the onboard IDE and 2 identical PCI SATA cards? What happens if I need to rearrange the cards to plug in a new device? What happens when I add a 3rd PCI card and a couple more drives?
I have:
/dev/hda = onboard IDE
/dev/hda1 = 'software raid'
/dev/hdb = DVD burner
/dev/sda = PCI slot 2, Sata drive 1
/dev/sda1 = 'software raid'
/dev/sda2 = /boot
/dev/sdb = PCI slot 2, Sata drive 2
/dev/sdb1 = 'software raid'
/dev/sdb2 = swap
/dev/sdc = PCI slot 4, Sata drive 1
/dev/sdc1 = 'software raid'
/dev/sdc2 = reserved
/dev/md0 = MD 'software raid 5'
/dev/mapper/picardVolumeGroup-<hostname><mountpointname>
(repeat 10 times)
It's a Xen system and I have 5 hosts configured to run on it.
Now tell me what happens If I plug a second drive into the second Sata to PCI adapter AND I add two more drives to a new PCI adapter on slot 3. Should I move the PCI adapters around to try to preserve the /dev/ names? Would that even work? What If I want to migrate the drives to a different machine?
The traditional numbering method works when you have a static machine, with local storage, and so on and so forth. Now you have machines were the storage is relative to how they are configured on the network with GFS and such.
Now that label stuff is news to me, and it's not going to solve my problems, but it seems like a step in the right direction. If you were aware of Redhat using fs labels to designate file systems, rather then specifying what paticular hardware device these file systems reside on, then it would of made more sense.
well.. DUH. 🙂
I know something is broken, but I don't know how to fix it. It's a fairly common occurance in my life, although it's less common for software then it used to be.
And if you have all your configuration based on /dev name then your screwed and things break.
For the device naming for USB devices you can now name them in your X.org config by part of of their USB identity strings that they send to the computer.
Instead of going:
Driver "mouse"
I can go:
Driver "evdev"
Also you can now refer to devices by their USB number and various other identifaction strings. You can find the names and such for devices by looking at /proc/bus/input/devices
Unfortunately X Windows has had this cronic problem were it can't realy interact with Linux systems developed to make desktop life easier.. Instead it's always had to depend on it's own drivers and configurations to deal with configurations that has been always independant from the rest of the OS. Hopefully with X.org being modular now modernizing all this will be much easier for devs to fix.
Eventually it'll get to the point were when you setup X you'll have the configuration program look for devices thru the 'HAL' to configure in this manner. It'll ask "What driver do you want to use for "Logitec Optical USB mouse"?" rather then you having to figure all this out and tell it what devices you want and how configure it.
My point was that this new 'LABEL" stuff was a step in the right way to try to fix this and although it's disconcerting at first N0c should learn to love, rather then hate. 🙂
Get a second server, it's better for you in the long run. And drop the SATA stuff, go scsi.
For most people SCSI is too expensive, especially if you want anywhere near the same amount of disk space. And SCSI is moving to serial attachment as well, there are already several SAS drivers in the kernel and from what I read on lkml SAS controllers will be able to handle SATA drives, not sure if the opposite will be true though.
But we aren't talking about most people, we're talking about big ass servers. Most people don't have big ass servers.
Agreed. But I assumed what drag was describing was a home server, having a half dozen drives and a few Xen instances at home doesn't seem too far fetched for me. But if it was a made up scenario, then yes they should have spent their made up money on appropriate hardware =)
