SlowSpyder
I dunno, I could say that I used 680 sli for ages at 1600p. How many VRAM issues? Oh yeah. None. But I didn't go silly with OGSSAA. So tell us what your experience with 1600p is please, go for it.
I could also be silly and link reviews from objective websites showing performance benchmarks between 2 and 4GB at 1600p. Guess what the performance difference is. Guess. It's a number between zero and..........zero. You get more mods and more SSAA with more VRAM. MSAA is unaffected, you can use all the MSAA you want. But once you go into stupid zone with SSAA, that's when VRAM use doubles or triples. That's also the same SSAA that chops your framerate by one half or more. Same with mods, if you want to go nuts with mods in Skyrim, you can do that with more VRAM. But saying more than 2GB is *required* at 1600p, nope, wrong. More SSAA, SGSSAA, SGSSAA, modding. That's about it. Performance difference: none. I'm not saying that if you want more VRAM it isn't valid, but you don't need more VRAM unless you're doing a silly resolution such as 7680x1440. 3GB is fine for 4k. I'd say 4-6GB is the area for 7680x1440/1600.
Shall I get you those reviews since you made the smirk in your post?
I've never had a 1600P monitor, so can't tell you... but that's not really how we do things around here anyway. Almost everyone here knows the FX CPU's are poor at gaming without having owned one, right?
2GB is probably ok at 1440P for most people. But if you don't want to limit yourself, I'd suggest a card with at least as much vram as the card I bought 2.5 years ago now, if not more... certainly not less. New consoles, new ports. Mods, higher AA levels. I'll take more vram than less at higher resolutions.
What is the benefit of less vram?
