olds
- Mar 3, 2000
- 50,127
- 781
- 126
NoOriginally posted by: galvanizedyankee
I'm not quite sure, but doesn't the new Hemi use two spark plugs per cylinder.
I ran that through the Google translator and still came up with nothing. Could you post that again using capitol letters and punctuation in the correct places?Originally posted by: alkemyst
the hemi never disappeared just stopped being advertised during the miserly period of cars I think was when it died out.
Just trying to understand.
I might be wrong, but I thought I had read that somewhere.
The hemi design was the choice for such marques as Duesenburg , Stutz, Miller and Offenhauser.
During World War 11, Chrysler was engaged in the development of aircraft engine and a V-12 tank engine which were to use the hemi head.
James Zeder and Ev Moeller were on the team after the war that looked into the Hemi for Chrysler. They looked at a Healey engine with a Hemi head and found it to be the most efficient design that they had seen.
They built a head for a Chrysler six cylinder engine , and called the experimental unit the A161. It was tested in the real world in a car driven by the head of testing Wallace Zierer. It passed the test and by 1948 they had a 330 cubic engine called the A182 , a V8 with hemi heads.
The Chrysler hemi engines really began as a " back yard " Ford conversion in the early 1940s.
Actually, no. I was so flabbergasted at your response I concluded that there was no reason to engage you in a battle of wits. While my time isn't all that valuable I did have some crud that I needed to remove from beneath my fingernails. In this instance, I was only trying to understand your point. But alas, you are so intelligent that your thought process moves faster than your fingers can type and it leaves us boors in the dirt. I defer once again to your great intellect and bow humbly in your presence.Originally posted by: alkemyst
ahhh you still all upset from the last post how you thought you are supposed to fill a radiator when it's hot and pressurized?
I am sure those of normal intelligence understood me, however, for the slow of brain:
the hemi never disappeared, [it] just stopped being advertised during the miserly period of cars...I think [that] was when it died out.
capiche?
Maybe the short bus has a hemi....
Å
My bad. I was thinking of the original hemi and didn't even see the word new.Originally posted by: Wolfie
Yes the new HEMI does have two spark plugs...
In this case, are saying that the hemi was built to the present day?
Carry on my narcissistic friend.
No, not in every case for everyone. In his case it was possible that he never got the system full in the first place. This is my understanding of how coolant systems work:Originally posted by: alkemyst
So you are saying the proper way everyone/most people need to follow to make sure they put enough fluid in their cooling system is to do it with a big thick rag and take the cap off while hot and pressurized hoping that thick rag blocks all the coolant and/or you don't make a big mess?
That just seems insane to me and perhaps I got lucky, but I have changed the coolant in about 10 different types of cars and each one I was able to mix up a batch according to the amount in the manual or even by simply filling it cold and never had a problem with low coolant or overheating. A few times I did have to add a touch after running it once and it cooled back down.
Å
Open the cap with a cold engine. Fill it up to the neck of the radiator. Start the engine and run it. As the engine warms the coolant will start to rise, stop filing as this happens and slowly add if it's not going to overflow. Then when it stays at the top install the cap. Let then engine continue to run until the thermostat opens and the coolant flows (on a modern closed system the fan should kick on when the thermostat is now open, an older car the upper radiator hose should get noticibly hotter...I always use the upper radiator hose to check). Now this is the step where is it hot and you open it....Open slowly with a large rag to relieve any pressure that has built up, it should be mostly air (if the system was low to begin with)...instead of hot coolant and since the thermostat is open a lot less pressure. The coolant should appear low, top it off again, then install the cap, fill the surge tank to the hot mark (if you have one) and go drive it for a few miles and repeat the process if needed.
The pressure in the cooling system is not from the pump, it's from the expanding coolant as it heats up.
The closed cooling system came about to reduce cooling system corrosion, this is accomplished because the older total loss cooling system allowed air to enter the radiator upon cool down, this accelerated the corrosion process, the engineers in their infinite wisdom decided to dump the expanding coolant into a reservoir, upon cool down the reservoir coolant is drawn back into the radiator, thus eliminating the air.
There is absolutely no need what-so-ever to continually top off the radiator when filling, just fill it cold, fill the reservoir and drive, upon cool down the system will automatically refill itself.
Right...however with the thermostat open you have a place for more pressure to go. Also if you drain a system completely and refill without letting the thermostat open I have found more often than not you can't get the full 'fill' recommendation in at all and once that thermostat opens you now can.
I hope this helps to show that the old 426 was NOT the only hemi engine.
The 426 was the only Hemi that mattered, an awsome machine.![]()
Certainly not, the 392 was the predecessor to the 426, but the 426 was the culmination of quite a bit of research and developement. I doubt many of the folks here have ever even heard of the 426 Hemi, much less the 392. Yes, our age is showing. The 426 Hemi cars were/are considered one of the truly great horsepower monsters from the days of real musclecars. Even in street trim, it was a beast to drive and to maintain but went like the devil.![]()
Originally posted by: redly1
HEMI this HEMI that, blah blah blah
Why did the HEMI engine disappear for ~30 yrs? What was it's downfall? Could/has the technology be incorporated into 6 or 4 cylinder engines?
just curious
