HELPP with hard drive while unziping
pchx
20
hello, i need help desperately. i just got a new hard drive seagate barracuda 7200.10 250gb sata2 . because i thought my old one was broken WD 250gb SEcaviar.
i installed windows on it and then every time i try to unzip something or even install an application gives me this error
PLEASE HELPPP
http://img320.imageshack.us/img320/590/untitledjd1.jpg PICTURE HERE!!!!!
techmanc
1,212
7
Try copying the file to your computer and see if it copies if it does run the setup from the hard drive and see if it installs
pchx
20
Lol, it something with the hardware, i just passed PRIME 95 and in less than 30 sec, i got this
[Mon Oct 23 23:07:34 2006]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
i went to bios, and rested it , and put memory timmings in auto. same ****** :s
jmagg
2,229
466
Memory problems will often cause decompression problems. Memtest.
pchx
20
hehe, yes i passed the Memtest on windows. i coudlnt install it on the disket.
so it showed some erros ass soon as i ran it.
so i tried to raise the voltage to 2.7 v and the problems still.
i used the defaults bios, and the problems the same
used autu timmings or the settings i used that the beggining and same problem
http://www.pureoverclock.com/review.php?id=25&page=1
this are the memories
jmagg
2,229
466
Memtest each stick individually. Possibly loosen timings.
Run cpu at rated speed.
I assume the machine ran error free at some pointin time.
pchx
20
lol they worked perfectly until i connected them again on the system, i might think that they got some damage in the luggage :mad::mad::mad:
