I am really having a bad day...........anyways.....I just got another stick of 256 MB of Crucial PC2100 DDR. I have two sticks of the same kind in my computer now. When I start up Half-Life or Counter-Strike and try to make a LAN game, it freezes up or gives me all this wierd sh!t on my screen. I already tried OpenGL and DirectX. Both of them don't work but software mode does.......
This is what I got in my computer:
Abit KG7
2 sticks of Crucial PC2100 DDR
Hercules Prophet 4500 64 MB Video Card
I think thats all you really need. I am also running Windows 2k Pro. I already updated my Video Card drivers, DirectX drivers, already uninstalled Half-Life and re-installed it..........I also set my processor to default speed (1.4 GHZ) so there is no stability issues here.......hopefully not........I am clueless what to do now........help!!!!!!!!!1
Thanks.
Edit:
I just called Crucial Tech Support and they told me that I should flash the BIOS, that is the only way it will be fixed. Is this true? I already tried to take out one of the sticks of memory and it doesn't do it, it acts normal. It is only with 512 MB of memory.........
Abit KG7
Thanks.
Edit:
