Gbaby1008
223
I was oc a little to like 190, i increased my voltage to 1.775 saved then restarted. Black screen nothin. I popped out my cmos battery, nothin, let it sit, nuthin, traded psu, video cards, memory, monitors, all nothing. I'm guessing. I fried either my mobo or cpu. But, the wierd thing is i've set it to 2.000v before. Did the same thing, fixed it by poppin the cmos battery out. And also right before it happend it was doin the same thing, and i popped out the battery like 5 times and it still works. I've also tried 2 different batteries from other computers.
Please help!!!
(No ones helpen in techs support)
Thx
GML3G0
1,356
you just have to move the jumper for 1.5-2 minutes. over that isn't necessary. i timed it :D
res0n0xg
Banned
Feb 22, 2004
361
computer is fine, they just don't stop booting up like that. do the standard shi!t, unplug all things and take mobo outside of case with vid card cpu memory and short the power jumper with a screwdriver on the mobo and watch it come up to the bios. if that doesn't work i don't believe that you cleared the cmos properly and will never believe you unless you video tape yourself doing it.
Gbaby1008
223
How do u short the power jumper? And also I've switched the cmos to 2,3 and left it like that four 10 min.
CaBoOse999
240
I had a similar problem I though I broke something because reseting my cmos jumper wasn't doing anything until I discovered by accident that I had to Take the power plug out.
compusaguy
109
This is the funniest post I've read all day.
