Here is a brief overview of my setup, I was about to make a nice visio drawing of this but then it didn't work! 🙂
Motorola SB510B Cable Modem
| cat 5 (into WAN port on router)
Buffalo AirStation WHR-HP-G54 running DD-WRT Firmware: DD-WRT v24 RC-6 (01/02/08) std http://www.buffalotech.com/pro...cess-point-whr-hp-g54/
| cat 6 (from port 1 on router)
Netgear GS108 GigE switch http://www.netgear.com/Products/Switches/DesktopSwitches/GS108.aspx?detail=Specifications
| cat 6
Netgear GS105 GigE switch http://www.netgear.com/Products/Switches/DesktopSwitches/GS105.aspx?detail=Specifications
I have 2 PCs plugged into the 8 port with Cat 6
I have 1 PC, Xbox 260, Wii, and Popcorn Hour (Network Media Tank) into the 5 port with cat 5
I am going to order some cat 6 so that all my cabling is the same
My problem is the 8 port switch just blinks all its lights when I have the cable from the router AND the cabloe going to the other switch plugged in.
I suspected that the 8 port was bad a little while ago, but I'm not sure. I want to make sure this setup is possible before I RMA it or something.
Thanks
| cat 6
Thanks
