imported_Shinigami
I'm trying to upgrade my system. However, since my current system isn't THAT bad, I feel I need to get a fairly modern system to justify the upgrade. My current system has 1.8Ghz Pentium with 1 Gig of ram. However, the processor is an outdated chipset (the pre-478 one that Intel quickly abandoned), the MB uses SDRAM, and the MB can't handle newer AGP video cards.
Here is the components I THINK I want to get.
ABIT NI8-SLI GR ATX Intel Motherboard
Intel Pentium 4 630 Prescott 800MHz FSB 2MB L2 Cache LGA 775 EM64T Processor
ATRIX 4in1 Combo CSCI-C8001-C43 Black/Silver Computer Case
As for memory, I'll just find what's a good bargain that'll fit in the MB I get.
I'm pretty sure that the processor and case I picked are what I want. However, i'm not sure at all about the motherboard. I'm not sure what MB on Newegg will work with the above processor. Frankly, it's not well marked. I only found the above one by searching for EM64T, which had 6 results. Is there a better motherboard for what I want. I'm looking at the $100-200 range, AGP, Max 4 Gig of ram or more, ATX form factor. Now that I think of it, I don't think the MB above even has AGP, just PCI Express.
I'm also wondering about 64 bit technology. I don't plan on getting 64-bit Windows XP, at least not yet. Is getting a processor like this a good move? What kind of expansion capabilities will I have? What kind of problems with the software I currently have will I run into.
Thanks in advance for the help.
