####HELP WITH REFRESH RATE PLEASE#####
Mr56k
33
ok this is what happened...
saturday i went to a local lan center and i brought my pc. i used their 22" sun crt and set the refresh rate at 100hz. i bring my computer home and i try to use my monitor. i load up my os and as soon as the windows xp logo disappears my lcd turns off and says "out of timing"
my lcd's max refresh rate is 76....how do i change it if i cant even see my desktop =(
PLEASE HELP ME ='(
edit: fixed the local MAN center rofl
Matthias99
8,808
If you hit F8 while booting Windows, you can come up in standard VGA mode (640x480, 60Hz), which will let you fix your video settings. Booting in Safe Mode might also work.
Mr56k
33
are you sure? i hope so. cause i tried safe mode and it doesnt let me change ANY of my video settings
Ackmed
8,499
560
saturday i went to a local man center and i brought my pc.
Im sorry.. that was just funny. :)
You shoudlnt be using the max for your LCD, 60hz is where it should be. Hz doesnt work the same was as LCDs that it does for CRTs.
Matthias99
8,808
Odd... you should be able to modify them (I think).
You can also come up in Safe Mode and uninstall your video card's drivers through Device Manager. This will force Windows to redetect your video card when you next boot up, and it will come up with safe defaults that your LCD should be able to display.
xtknight
12,974
why what happens if I use 75Hz on my LCD?
2Xtreme21
7,044
Nothing. I personally think the 2d quality is better with 75Hz on my LCD.
