Originally posted by: mechBgon
That works fine, I have the same.You should run the RAM at PC2700 speeds so it's synchronous with the CPU's FSB, however, so yes, you could also opt for PC2700 if you don't want to overclock and/or pave the way for a future upgrade to a 400MHz-based CPU.
Originally posted by: sinthon
So if I use my Barton core 2500+ at 333FSB I will have to underclock my RAM?
