Originally posted by: dsj
I just put that thing together. The case is 39 canadian with a 300 watt power supply. I think the power button is broken. Is that the most likely problem? I just assumed that it isn't an ATX case because it's cheap.
The case has an included power supply for 39.00 Canadian? Isn't that like $1.50 US (sorry I forgot our dollar has no value anymore).
That could be your problem there. What is your system?
I know you can do something to the motherboard like connect some jumpers to power up the computer. What was that procedure again? I want to see if it's the power switch's problem.
Thanks. So I just connect those pins with a screwdriver then it will power on?
I tried and it didn't work. So it's not the switch. But I can't figure out what's wrong. It won't even power up. The motherboard's led is on when the power is plugged in but the computer won't start.
Yes. The 4th and 5th pin. I connected them with a screw driver and a copper wire. the motherboard used to work before with another case and PS. What could be wrong? The mother board really didn't seem to have a 4 pin power plug. Only the 20 pin one.
Asus A7N8X deluxe
Is that what you meant?
