Well, the funny part is... this was a misunderstanding, from the get-go -- and a joke gone awry, if you will!
Originally posted by: VinDSL
I used the Calculator link that 'Baked' supplied. I *think* it's pretty accurate! It calculated 414W for my system rig...
The thing is, it has an LED output load meter on it... and my rig idles at approx 200W. That's just the 'box', not the monitor, and so forth. When I do ANYTHING intensive, it pegs the display (300W). It's VERY possible that this thing is actually using 414W at 'the wall'... maybe more...
What I meant by that was, the calculator judged my rig to consume 414W at the PSU, and that's fairly accurate, because I'm probably using that or more at the wall. I just picked 414W to be cute. I wasn't suggesting that's how YOU should calculate your power needs. It was simple an idle observation. On the other hand, if the calc said I needed a 414W PSU, and my UPS was only showing a 75W power output, that would give me pause, although the two don't have much to do with each other.
As an aside, I used to run two computers, two monitors, two modems, a hub, and a printer on this UPS, and it would run for about 5 minutes, when the power went out. With this machine, it won't even handle 'the box', even with fresh batteries -- and that amazes me -- soooo, put another way, it doesn't surprise me that this thing requires a 414W PSU.
That's all I was babbling about, but everyone jumped on that like flies on stink -- said they didn't know what I was trying to prove, except my ignorance, and so forth, so I decided to have some fun too.
Anyway, I guess I was too convincing, and I'm soory that you got caught up in it. I tried to *warn* you with the 'fish on the line' comment, e.g. I was reeling them in, but I guess that was too enigmatic. I suppose I should have PM'ed you... but I didn't... oh, well. Live n' learn!
