- Jul 17, 2003
- 753
- 0
- 76
Hey, I've been looking to get a power supply for my new Core2Duo rig that may go *Crossfire* (I was using SLI to refer to two gpus generically) in the future, so I was looking for something with a decent amount of wattage. The other criteria would be $100 or less (a little flexible if I need to be) with good efficiency and rock solid rails. Being really quiet or pretty isn't a necessity.
I came across this PS: Sparkle FSP650-80GLCR at E-Wiz and according to the only review I could find, it seemed to do pretty well (although it wasn't a final production model).
How is this PS? Is there any other that people would recommend in my situation? I'm aware of the Seasonics, but the only one near my price range is the S12 500W and I'm not sure that would be enough juice for an Crossfire system.
Thanks in advance for any help.
EDITED for clairity.
