Hello, trying to build for the summer to help me be more of a nerd. I have not built a comp for 5 years, so I'm really out of the loop. Anyways on with the questions and prelim build:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming only.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1300
3. What country YOU will be buying YOUR parts from.
Canada
www.ncix.com
and
www.newegg.ca
I prefer ncix though I have dealt with them a lot, and their prices seem better.
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
No preference.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I don't need a monitor, keyboard, mouse.
6. IF YOU have searched and/or read similar threads.
Yes, some to get an idea.
7. IF YOU plan on overclocking or run the system at default speeds.
Default, will never be overclocking.
8. What resolution YOU plan on gaming with.
1920x1080
9. WHEN do you plan to build it?
Sometime in the next 2 weeks hopefully.
With a $1300 budget I fell short of the max with this build on ncix, didn't settle on anything just playing around. The prices are after combos/deals
LG GH22NS50 Black 22X SATA DVD Writer OEM - $23.99
http://www.ncix.com/products/index.p...5&promoid=1219
Azza Solano 1000 Black ATX Full Tower Case 10X5.25 1X3.5 8X3.5INT 2X230MM LED Fans & Window No PSU - $96.99
http://www.ncix.com/products/index.p...6&promoid=1219
OCZ OCZ3G1333LV6GK Gold 6GB 3X2GB DDR3-1333 CL9-9-9-20 240PIN DIMM Triple Channel Memory Kit - $169.99
http://www.ncix.com/products/index.p...8&promoid=1219
Seagate Barracuda 7200.12 500GB SATA2 3.5IN 8.5MS 7200RPM 16MB Hard Drive OEM *3YR MFR Warranty* - $52.99
http://www.ncix.com/products/index.p...0&promoid=1219
ASUS P6T SE X58 ATX LGA1366 DDR3 LGA1366 3PCI-E16 PCI-E1 2PCI CrossFire SATA2 Motherboard - $213.99
http://www.ncix.com/products/index.p...2&promoid=1219
OCZ ModXStream Pro 700W ATX 20/24PIN SLI Ready Modular Cables 135mm Fan 80PLUS Power Supply - $89.99
Intel Core i7 930 Quad Core Processor LGA1366 2.8GHZ 8MB L3 Cache 130W 45NM Retail Box - $315.99
http://www.ncix.com/products/index.p...3&promoid=1219
XFX Radeon HD 5770 850MHZ 1GB 4.8GHZ GDDR5 2XDVI HDMI Display Port DIRECTX11 PCI-E Video CARD- $184.99
Free Ubisoft ASSASSIN''S Creed 2 PC Game Steam Digital Download ** Intel Promo Only **
After taxes, shipping and rebates it goes down to $1175.
Thoughts?
Gaming only.
$1300
Canada
www.ncix.com
and
www.newegg.ca
No preference.
1920x1080
Thoughts?
