I've installed the host version of PC Anywhere (v 11.5) on a friends PC. His setup is as follows. He has Qwest DLS with a Cisco 678. Then, a DLink DI-524 is connected. I'm trying to access his machine from my home. I've set this up before with a Linksys router and it worked fine. However, this guy has a new PC and I'm betting I overlooked something simple. Seems to usually be the case when something happens. Any ideas?
DLink router is configured correctly to allow 5631/5632 to pass through to the correct IP for his machine. The only thing that comes to mind at this point is that I may have overlooked adjusting the firewall to let PC Anywhere access to this machine.
Also, it sounds like you can setup PC Anywhere to access more than one machine on the LAN. Apparently you just need to assign different ports to use (other than 5631/5631 since they were used already on the LAN by another machine). Which ports make sense to assign?
Thanks!
Thanks!
