help with motherboard monitor
Well it's a little impossible to tell you if it works with your motherboard..since you didn't bother to tell us what you have..but if you can find a similar board in the config wizard it may work..
um, it's below the title bro.
Ah, didn't see that, it's easy to see if it's in the post rather than just in the title..but anyway, just see if you can find any similar motherboards in the setup, and try it out. Or maybe a google search will turn up what sensors the board uses and you can set it up manualy.
You'll have to manually set it up. Just try different sensors and see which ones work. I got my Epox nForce3 Ultra board configured that way.
