Help with Mazda3 front license plate mount
Status
Not open for further replies.
ivan2
5,772
www.heatware.com
Does anyone know what size and type of screw they use to screw the license plate mount onto the car? I got a aftermarket front plate mount from rockauto but the screw doesn't come with it.
PricklyPete
14,582
162
Don't most Euro/Asian cars use M6 1.0 for license plates? I believe both our Audi and Toyota do.
ivan2
5,772
www.heatware.com
im reading the words that's molded onto the plate holder, it does say use 6mm self tapping to screw the plate onto the holder, but do i use 6mm screw to screw the holder onto to car too?
NutBucket
27,152
635
If there aren't any threaded inserts then possibly. What does this beast look like?
AMCRambler
7,715
31
So this thing screws into the front of your bumper? Ew. I never bought a plate holder for my Contour because I didn't want to screw into the bumper. Instead, I bought two right angle brackets at Home Depot and screwed into the bottom of the bumper. This way if I ever took the plate off it wouldn't ugly ass holes that were visible.
jlee
48,518
223
A friend of mine bought a license plate bracket for his MS3 that bolts up to somewhere on the passenger side of the front bumper...no drilling into the bumper required. Might be worth looking into.
kornphlake
1,567
9
Just use some double stick tape, the good stuff is pretty much impossible to remove, but if you need to for some reason a little solvent should do the job without making holes in your bumper.
ivan2
5,772
www.heatware.com
hmm, i know what ur talking about, his got a thingy to screw it into where you will put the tow hook. main reason I went for the bracket is because i bought the thing used and there's some scratch on the bumper and a bracket will cover it up perfectly. Which brand has good double side tapes?
Status
