help with lock!!!
Originally posted by: OMG1Penguin
Precision screwdriver (flathead, NOT phillips). Works like a charm.
Here's your answer! A small screwdriver, or any similar shaped "blade" that will fit through the 1/4" hole.
Originally posted by: RagingBITCH
You're such a n00b. If it's not a push-in privacy lock, then it's a slit edged lock - the lock that you turn will be like || so you're going to have to make a flat edge with the paperclip.
Quiet, you with the functional nonviolent ideas. I want to see pics of the aftermath when he pulls a SWAT-team imitation. 😀
- M4H
He's so worthless he'd probably snap his leg in two when he tries to kick the door in. Or he like runs at the door, jumps, and bounces off and dislocates his shoulder on impact with the ground.
He'd really have to be pathetic to bust a limb on a door. Shit, I'm a hundred and forty soaking wet and I can bust anything that's not a deadbolt. 😛
- M4H
Get a coathanger, bend it into a longer hook. Now, hoping it fits in the little gap, just to the right of the lock between the trim and the lock, put the hook through, pull down, then back toward you.
That is, assuming the credit card doesn't work because the flat side of the lock is facing you
Print out g*atse, then tape it to the lock 'hole down'. After ten minutes, your lock will be soft enough to remove with a butterknife.
