Raduque
I've got this headset that the dog chewed the cable apart on. It's a Turtle Beach EarForce X11 wired headset (USB powered, analog headphone jack input).
It has 4 wires in the cable:
Insulated red wire wrapped in a copper wire
Insulated green wire wrapped in a copper wire
Insulated blue/gold wire wrapped in a copper/red wire
Insulated blue wire wrapped in a copper/blue wire
All four outer wires are touching inside the outer rubber sheathing. The insulated inner wires all have some sort of soft, white thread running through them.
From what I've found on the net, the insulated blue wire wrapped in the copper/blue wire is the USB power, the blue/gold wrapped in copper/red should be the mic wire, and the red and green wires wrapped in solid copper are the right/left of the earphones.
However when I connect all the like-colored wires up from each end of the severed cable, I get nothing. The light on the control box doesn't light up, and I get no sound. I can't even get a small light bulb to light up when I connect the exposed ends of the USB hot/ground wires to it.
Help me out here? What am I doing wrong?
