I swapped motherboard in my computer because I had Direct3D issues where it crashed to desktop every time I tried some D3D games. With the change that problem is gone but now I have a new problem.
Every time I try to install a game from CD drive to hard drive the whole system crashes and reboots. It also happens when copying a large file from CD to hard drive. For instance BF1942 installation first complains about corrupted media but if I can get it past that it crashes at around 50% of the installation (around where map rfas are installed). Ghost Recon installation also crashes about midway through.
This happens with both my Liteon 4012S CDRW and with LG 16x DVD drive. I replaced all IDE cables with brand new ones. I'm running XP Home.
I'm thinking some IDE setting may be the cause but I'm little unsure what parameters to change. Any help would be appreciated.
Other hardware:
Gigabyte 7ZXE motherboard
Athlon TB 1.4GHz (temps should be okay CPU temp 56C, system temp 29C)
512Mb SDRAM (tested with memtest86, should be okay)
MSI GeForce3Ti200
Seagate Barracuda IV 80Gb
Turtle Beach Santa Cruz
3COM 905C LAN card
Antec 430W TruePower
Other hardware:
MSI GeForce3Ti200
3COM 905C LAN card
