Help with first build
bostrom32
41
ok, put everything together and nothing. unhooked everything but a fan it would come on, hook up hd, no dice. psu came with case, so went and got a new psu, hooked everything up, it started posting, then said safe mode and checksum error, then the monitor read save power mode. cant get it out oif save power mode, put vid card back in my old pc and it works? everything is powered up, i think. speaker was working earlier not now....help
newParadigm
3,667
Your mobo is more than likley shot, or possibley your CPU, are you getting any kind of beep codes?
Cook1
6,315
Sounds like your motherboard if you can't post now. Same thing just happened to me a few days ago, and now I'm waiting for a new one.
Fern
26,907
174
Sounds like you may be trying to install HD with previous install of Windows.
If the previous install of windows was done on a system with different hardware, i.e., mobo you are likely experiencing driver conflicts.
If this is the case, I always reformat/reinstall.
Otherwise, here is an article on how to do it w/o a reinstall LINK
If I have misunderstood, please consider taking your time to post a more carefully written and detailed explaination.
Fern
bostrom32
41
yea it posted for a minute, now cant get monitor of the power save screen, no beep codes now
cleared cmos and got beeps, need to know how to get them back?
