Hi everyone. I recently built a new PC and am thinking of upgrading my DDR4 RAM to 32gb. Its always confused me a bit knowing how to understand timings and compatibility and how to tweak for optimal performance. What confuses me is that my mobo supports a big range of RAM speeds, but from my understanding, my CPU limits (or works optimally?) with 3200mhz when using DDR4, which I am. So does that mean I should only look at 3200 speeds or can I buy faster 3600 or 4000mhz? I hope you can help me figure this out and look forward to some recommendations. Here's my current setup:
CPU Intel Core i5-12600K
MOBO ASUS TUF Gaming Z690-Plus WiFi D4 LGA 1700
RAM Corsair Vengeance LPX 16GB (2x8GB) DDR4 DRAM 3200MHz C16 Desktop Memory Kit – White (CMK16GX4M2B3200C16W) Timings 16-18-18-36
GPU Nvidia 1070, I plan to upgrade to a RX 6700 XT or a RTX 3070 soon
Thoughts on what i should do with RAM:
1) stick with what I have currently.
2) buy another 16gb of the same model
3) buy new 3200mhz ram, if my current could use an upgrade
4) buy new ram in a different mhz speed. I'm open to kit suggestions!
I dont need RGB but I do like the T-Force Xtreem ram and read lots of great reviews.
There's a good sale on their 4000mhz set but its CL 18 and the timings are 18-24-24-46. Isn't that overall slower than what I have? The reviews I read are glowing unless they're comparing faster models which i dont think so. The other options like CL 14 are much more expensive so I'd like to buy the CL18 if that will work well. Speed is great but I don't need ultra crazy fast, I just would like a good setup.
www.newegg.com
I do have some slowdowns from time to time and available memory can be low so it makes me think 32gb might help. I'm a general PC user who likes to game, not video or graphics design, fyi. Thanks in advance for your thought and helping me sort this out!
Are you a human?
