- Apr 2, 2005
- 6
- 0
- 0
Hi
i need some advise here pls...lemme ask the vital question first - does reliance rconnect support the 'multilink PPP' protocol?
i have been tryin to use two dial_up modems at the same time to double the available bandwidth...
i was googling on it and it seems quite possible- the technq goes by different names - 'bandwidth aggregation'...'shotgun'... microsoft calls it multilink PPP and even has a help page (KB304879)...seems xp can handle this double_modem thing.
so, i followed the info gathered to set up two seperate modems first and then two seperate dial-up cnxns...[there was a check-box called 'negotiate multilink for single-links' in dial-up_properties>networking>settings which i checked(as advised)].
so far so good...both the cnxns connect perfectly alone, but whenever i dial the second cnxn, the first one goes idle
what am i doing wrong?
do i need some special permission or code or somethin like that from reliance to be able to use this ?
i noticed this too-might be crucial - in dial-up_properties>options the section 'Multiple devices' always remains unclickable/greyed_out...i guess this is part of the same problem.
pls guide me on this one...
thanx
edit: there's this software called midpoint which is made exactly for this purpose, but it needs static ip's to work with (rconnect is a 'dynamic ip' syatem and so i cant use it.)
thanx
