CreativeTom
Banned
I am ready to order for a new system, I am going to go with the Zalman 7700cu cooling fan for the processor. I have a question on that fan, do I need to get a separate heatsink??? how does the fan mount????
I think the zalman is a hs, and you might get a fan with it. the fan mounts like any hsf, on top of the hs. just follow the instuctions that come with it.
That's what I thought kind of, but do I get a fan??? if not can anyone recomend a fan to go with it????
give me a link to where you are buying it. if you don't get a fan, most people reccomend panaflos for cpi hsf's
OK, I was going to get it at Monarch, and stupid me didn't see that they sell it with or without a fan. The question I have now is the fan that comes on it worth it, or should I just go with something else. I am not real concerned about noise, I just want something that cools really well.
not trying to be a smartas$, but just try it and see if you like the temps. then buy a new one if you don't like it.
I know you are trying to help and thanks, but I would reather not guess when I buy it and then if I don't like it go and buy another one. I am not the type who likes to spend money....lol
oh, so you are not going to get it if the fan that comes with it is not good?
