Help with calculator? google
dighn
22,820
4
Originally posted by: DVad3r
How do I suck at math? I don't live in the US, I'm using the metric system son. Is it my fault that google gave me the wrong numbers? gtfo back into your troll cave peon.
you were just ignorant of the imperial system which is forgivable because it is a horrible system. but google did not give you the wrong answer. 5.9 ft is not 5'9"
Oct 27, 2007
17,009
you are doing it wrong. 181 centimeters = 71.2598425 inch = 5 feet 11.26 inches
How? It's google calculator. Go to google and type in 181 cm to feet and hit search:
181 centimeters = 5.93832021 feet
More about calculator.
well you gotta remember that the empirical system sucks. 12 inches in 1 feet.
:laugh: You mean the imperial system?
Oct 27, 2007
17,009
Originally posted by: RESmonkey
It seems he's not from the US. Since we use such a backwards measurement system and not metric, outsiders aren't aware of the 12 inch in a foot thing.
No, this is good old fashioned stupidity. I don't know anyone who doesn't know that 1 foot == 12 inches. We may use the metric system day-to-day but we're still very aware of the imperial measurement system.
ManSnake
4,749
That's a serious math fail right there.
He lives in Canada, which is USA-lite, plus Canada is a part of the empire, so no excuses for him.
cyclohexane
2,837
19
THERE ARE TWELVE INCHES IN A FOOT
12*.9 =~ 11
Oh, so that's why subs have 12 inches, cause they are a foot! Mmmm, Mr. Sub, Mmmm
OP is a retard.
gorcorps
aka Brandon
Jul 18, 2004
30,741
456
^ Sir I am very offended by your comment.
Being called retarded is less of an issue in the states as being called Canadian... be thankful
oboeguy
3,907
Try converting to beard seconds instead:
181 centimeters = 362 000 000 beard seconds
daw123
2,593
What I don't understand is why the dimensions for some things are specified as a combination of imperial and metric units.
Two examples, which spring to mind:
Tyres: 17" diameter with a width of 225mm
Timber: 2" x 1" X-section and 3000mm long
wtf.
Why don't they just convert the whole lot to metric and round it to the nearest 5mm. In the timber example I gave above, it would be near-as-dammit 50mm x 25mm X-section by 3000mm long.
The tyre example:
13" Tyre ~= 330mm
14" Tyre ~= 355mm
15" Tyre ~= 380mm
16" Tyre ~= 405mm
17" Tyre ~= 430mm
etc.
It would make my life so much easier (I work in the construction industry), since I've always been taught how to use metric units. I know how to convert between imperial and metric (25.4mm = 1" and 12" = 1') but its laborious.
Also in the UK, it seems that EU law is deliberately trying to phase out the use of imperial units (remember a couple of years ago when grocers, butchers, shops etc. were forced to have all weights shown in g and kg as well as lb).
jman19
11,225
664
/facepalm
Firebot
1,476
Canada still uses inches to measure height and pounds to measure weight.
silverpig
27,703
12
No it doesn't. My driver's license lists my height in centimetres and my mass in kg.
A lot of people around here still use feet and pounds, but it's just a throwback and is disappearing.
MotF Bane
60,801
10
So I'm trying to convert my height and I'm 181 cm tall. According to google calculator I'm 5 foot 9, but when I punch in 5 foot 9 inches to cm it gives me 175? wtf?
For posterity.
MotF Bane
60,801
10
For posterity.
lxskllr
60,209
10,666
To change inches to decimal feet, example... (5'10-3/4") 3/4+10/12+5=5.8958'
Edit:
for completeness
