Help with borked flash on 2 980Ti hybrids
DaveT231
In my quest to push my two hybrid Ti's to the max I flashed both cards one after the other using what I thought was a good rom instead of flashing one to make sure every thing was good before bricking my over card as well. Still kicking myself for that but I was wise enough to save each cards stock Bios's through GPU-Z the flash was done with nvflash and a 900 series flash guide that I found. Everything appeared to go fine with the flash until I couldn't boot with the cards in so I had to pull them and boot into my Asus Z170 Hero's bios and switch priority to the Igpu to be able to get back booted into Windows and then shut down and added the top card. I tried to flash back to my backed up bios but got errors every time and even found the right bios and tried flashing it and still no go. Anyone have any advice? Should I put my old 750Ti in the top slot and the 980 Ti in the 2 nd and try again or make a bootable flash drive to try the flash from or even go for the Hail Mary and setup a blind flash?
Okay now that I'm not on my phone here is the procedure I followed for the flash http://www.overclock.net/t/1523391/easy-nvflash-guide-with-pictures-for-gtx-970-980
With this rom http://forums.evga.com/GTX-980-TI-BIOSVOLTAGE-HACK-m2360712.aspx
and this is the recovery bios I've been trying to use https://www.techpowerup.com/vgabios/175164/evga-gtx980ti-6144-150609-1
There's a screenie of my errors I get
Well just tried with my 750Ti and the heart break continues. I guess next step is to make a bootable flash drive.
