Termie
Checking in here.
So I *think* my settings are 9-9-9-24-2N.
I am in the BIOS right now and under DRAM Timing Configuration, there is:
XMP 1.2 Profile 1: DDR3-1600 9-9-9-24 1.50V
Below that there is "Load XMP Setting"
It has the options for "Auto" and "XMP 1.2 Profile 1"
Going to guess here and say I should select the "XMP 1.2. Profile 1" option?
I do a little but further down, under Voltage Configuration:
DRAM Voltage: 1.500V
Little different BIOS for me, so I am learning my way around.
Anything else I should check?
That looks right - go ahead and load the XMP profile, restart, and check the BIOS again to see what it actually set.
You haven't made any other changes in the BIOS, correct? If not, then let's see if uninstalling and reinstalling the drivers works. You might try a utility like Driver Sweeper to pull all the old Nvidia driver files off the system.
